Old 09-09-2014, 02:35 PM   #1
59ORLander's Avatar
Silverton , Oregon
Cell phone coverage and Airstreams..general Q
Does the aluminum shell of an Airstream interrupt reception at all?
Just daydreaming of a mobile office/home
59ORLander is offline   Reply With Quote
Old 09-10-2014, 06:46 PM   #2
TBRich's Avatar
2006 19' Safari SE
Tucson , Arizona
Images: 64
Surprised no one has given you any input so far. We have never experienced serious service issues on our cell phone inside the Airstream. I suppose it could be a problem if the signal in the area is weak to begin with, but we have not had an issue. We use Verizon service and also use a Verizon MiFi device for internet connections inside the Bambi with no probelms.
TB & Greg and Abbey Schnauzer
AirForums #21900 . Membership Chair & PastPrez, 4CU/WBCCI
#3954
Old 09-10-2014, 06:52 PM   #3
Southwestern , Ohio
Probably, but enough signal leaks through the windows and doors that it's not very noticeable. (The screens in our trailer are fiberglass.)
An outside antenna will always help.
Nuvite-F is offline   Reply With Quote
Old 09-10-2014, 06:56 PM   #4
Full Time Adventurer
BoldAdventure's Avatar
2007 27' International CCD FB
Nomadic , USA
Should of posted in the electronics section for more replies. Aluminum is not good for cell reception. Think faraday cage. A signal booster and external antenna are a good bet.
Family of 5 exploring the USA with a Ram Power Wagon & Airstream in tow.
OUR BLOG | INSTAGRAM
BoldAdventure is offline   Reply With Quote
Old 09-10-2014, 07:04 PM   #5
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
But it can be a porous faraday cage, we've not had problems with pano windows both ends and more on the sides and top.
Doug and Cheryl
Old 09-10-2014, 08:34 PM   #6
acstokes's Avatar
2009 30' Classic
Melbourne, FL , Searsport, ME
I've never noticed any loss of signal or signal deterioration with either our iPhones or routers. I also have a wireless rear view camera that transmits to my iPhone in my truck cab and at distances up to 75' from the camera.
Fred Stokes
RV Rearview Camera Systems, LLC
WBCCI #2810
acstokes is offline   Reply With Quote
Old 09-10-2014, 08:49 PM   #7
Hibby's Avatar
2018 33' Classic
2015 30' FB FC Bunk
2012 30' Flying Cloud
Grand Rabbits , Michigan
Images: 20
I have installed a Wilson Signal Booster with External Antennta and my reception goes from 4 bars to 5 bars instantly. The cradle is inside the camper, whilst the antenna is mounted securely to the roof with aircraft adhesive.
Hibby
Hibby is offline   Reply With Quote
Old 09-11-2014, 07:09 PM   #8
2013 23' International
madison , Wisconsin
I’ve been thinking of adding a Wilson cell booster. Which antenna did you install? Were you concern about a ground plane for the antenna? I think the magnetic roof mount antenna used in cars allows the car roof to be the ground plane.
jim1949 is offline   Reply With Quote
Old 09-11-2014, 07:53 PM   #9
Hibby's Avatar
2018 33' Classic
2015 30' FB FC Bunk
Images: 20
Originally Posted by jim1949 View Post
Iíve been thinking of adding a Wilson cell booster. Which antenna did you install? Were you concern about a ground plane for the antenna? I think the magnetic roof mount antenna used in cars allows the car roof to be the ground plane.
Jim,
Here's the link:
http://3gstore.com/product/4736_wils...er-460107.html
This setup includes everything... I had the antenna mounted on top of the trailer, and I don't know how that affects the ground plane since it's aluminum, but I've been using one since 2012 for high speed internet and have yet to find somewhere that it doesn't work well.
Hibby
Wifi antenna and Cell phone question rodsterinfl Electronics & Connectivity 24 07-28-2012 10:26 PM
Cell Phone and Brake Controller Turtle Brakes & Brake Controllers 6 03-31-2011 05:44 AM
Cell Phone Repeater and Improved External Antenna Installation grantrc Phone, CB & Ham Radio 9 10-06-2010 09:53 AM
Solar Charging Panel and Cell Phone Antenna noiva Generators & Solar Power 15 01-16-2006 05:06 PM
Cell phone provider question (T Mobile) yargseth Electrical - Systems, Generators, Batteries & Solar 20 04-10-2004 06:39 PM
