Old 03-24-2013, 06:55 AM   #781
Originally Posted by HiHoAgRV View Post
Gas Light - it's possibly our favorite item in Dolly. We took very good care to store it in a safe place during the rebuild, we didn't want it getting damaged!
I don't think it was a factory install simply because of some goofy plumbing, I do believe it's an dealer - or very early owner - installed accessory. It gives of an almost silent hiss and a warm glow that shines off of the bare aluminum skin.
I tested it with a Coleman mantle, I need to get the larger proper one. Everyone's 1st question - 'Is it safe?', well...it's been there for about 50 years...
My 63 Overlander has one that appears to be original from the clean installation, but it's mounted on the bulkhead between the bedroom and streetside galley, to the left of the sink. It's not the type that has a glass shade though, it's not as pretty as yours.
Old 03-24-2013, 08:37 AM   #782
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
We recognized it as a gas light. I remember those in our 19ft something-or-other SOB trailer when I was a teenager (boy, that'll date me!), but not as pretty as yours. We would use them when it was chilly outside as they give off heat too. If I ever come across a pretty one like yours, HiHo, I'll buy it!
Kay
Old 03-24-2013, 09:08 AM   #783
Danruehl's Avatar
Brighton , Michigan
I've got mine stored away as well. Identical but with a different globe.
Danruehl is offline   Reply With Quote
Old 03-24-2013, 10:15 AM   #784
Kay
They pop up on Ebay and vintage trailer ad sites from time to time. They were used on many brands of trailers in the 50s and 60s, so they're not completely uncommon.
Old 03-24-2013, 04:19 PM   #785
Central , Mississippi
I have seen a bunch of different styles of gas lamps on ebay, never one with that type of globe. The only problem with adding one is gettin a 1/4 copper line up there. Mine was, and still is, exposed on the wall.
I crawled on the wet cold ground today and finished the under-belly piping. I HATE working underneath! Sprayed everything with soapy water -no leaks - and proceeded to 'fire' everything up. Hot Water from the 1963 Bowen, refrigerator kicked off on the 4th click.
Happy Dance!
Oh, here is my leftovers from the $150 photo (It would have been $200 but I recycled most of the flare nuts from the original copper)
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie(RIP) -
A honkin' long 34' named AlumaTherapy https://www.airforums.com/forums/f20...num-54749.html
and a 26' '63 Overlander, Dolly https://www.airforums.com/forums/f10...ome-71609.html
Old 03-26-2013, 04:40 PM   #786
Chillpoints's Avatar
1992 29' Excella
Asheville , North Carolina
Continue to be amazed
Vernon
I continue to check back on your progress. I began reading your thread when I first learned that we were going to inherit our trailer. Your work is always exactly how it should be done. Thanks for continuing to document the process.
The propane light reminds me of the ones we had in our cabin in Canada. Just seeing the photo brought back many memories of reading or playing cards while the soft hiss was heard over your shoulder. Would love to add a similar fixture to my Excella just for memories sake.
I look forward to watching the final pieces come together.
Jon
Jonathan Hettrick
'92 Excella 29'
Dodge Ram 1500
AIR # 59179
TAC NC-12
Chillpoints is offline   Reply With Quote
Old 03-27-2013, 05:35 PM   #787
Originally Posted by Chillpoints View Post
Vernon
I continue to check back on your progress...I look forward to watching the final pieces come together.
Jon
Thanks for the feedback Jon, we are slowly working the details as they get fewer and smaller.
Today the Easter Bunny made an early delivery...4 new Marathons. I'm gonna go ahead a repack the bearings on the old axles - yes, I'm buying new axles but that's gotta wait a few months...
Old 03-27-2013, 05:50 PM   #788
Minno's Avatar
1972 31' Sovereign
Are all the rims green? Or are they different pastels, like Easter Eggs?
Chris
Old 03-27-2013, 05:53 PM   #789
Originally Posted by minno View Post
are all the rims green? Or are they different pastels, like easter eggs? :d
chris
lol!
Old 03-30-2013, 06:38 PM   #790
This time of the year is about the only chance for polishing. I did a quick pass, it still needs a bunch of cyclo work but its a 50-50 job right now.
The lower fridge vent looked like crap so I hit it with the wheel and nuttin happened...I had forgotten to strip off the clear coat...
New tires are mounted, bearings greased...I'm down to a very short list of stuff.
Mrs HiHo has really gotta get back on the interior polishing! We have a Rally in 2 weeks...
Old 03-30-2013, 07:20 PM   #791
Who makes the blinds that you have
0557 is offline   Reply With Quote
Old 03-31-2013, 07:50 AM   #792
Mrs HiHo's Avatar
http://www.stevesblindsandwallpaper....FQ_pnAodvR4AXw
Mrs HiHo is offline   Reply With Quote
Old 03-31-2013, 07:57 AM   #793
Mrs HiHo's Avatar
That'll happen when you get me a new hand polisher.
Old 03-31-2013, 10:29 AM   #794
Minno's Avatar
1972 31' Sovereign
Soooo, I was looking back at your kitchen upper cabinet, since Chris is working on ours, and we were trying to figure out depth.... You are every bit as much a master cabinet maker as Chris is, if not more, Vernon. Those curved cabinets and corners are works of art!
Kay
Old 03-31-2013, 05:07 PM   #795
Kay
I copied the height of the original cabinet faces, 14". The resulting depth worked out to 16" based on the curve of the wall. Your milage may vary...
We finished the shower curtain, by 'We', I mean Mrs HiHo sewed on the hangers, I cut the top to match the curve of the roof. Of course I cut the curve so the pattern is on the INSIDE of the shower...
It looks really good from inside the shower...
Old 04-01-2013, 05:23 PM   #796
Minno's Avatar
1972 31' Sovereign
So, you will need to buy another shower curtain that matches, cut a mirror image curve, stitch them together back to back, and Viola: beautiful shower curtain both inside and out. Problem solved!
OORRRR, flip the shower to the other side of the trailer! Whichever is easiest...
Kay
Old 04-02-2013, 08:38 PM   #797
So, you will need to... flip the shower to the other side of the trailer! Whichever is easiest...
Kay
Hummm...thats a British conversion, right? Would I need to move the steering wheel and drive on the wrong side of the road?
Old 04-05-2013, 04:11 PM   #798
Minno's Avatar
1972 31' Sovereign
I don't know. That might get a mite messy..... maybe if you drove backwards on the road, then the shower would be on the correct side. Would that help?
Kay
Old 04-06-2013, 06:50 PM   #799
Kay
For $14, I think I'll just order another curtain...
Today we polished, waxed and installed a few new gadgets. A magnetic knife holder and a plexiglass back splash.
The propane tanks are better, I have no desire to get a mirror surface on them.
Mrs HiHo spent the day polishing off my fingerprints from the interior.
I added a coat of wax to the exterior so rain spots won't make me mad.
Everything was going good until the mudbugs arrived - after that, productivity went to zero.
ID:	182640   Click image for larger version
Name:	polished tanks.jpg
Old 04-06-2013, 07:41 PM   #800
Minno's Avatar
1972 31' Sovereign
Hi Vernon,
What wax do you use? We're looking for recommendations.
Is mudbug another name for crawfish? Never heard of mudbugs before.
Chris
1963, overlander, restoration
