04-23-2012, 05:45 PM
#501
Central
, Mississippi
Vent stack issue is resolved...thanks Becky!
I did get a few things done this weekend...tub tested good, no leaks in the drain system so it's installed.
The new flooring arrived last week so it is now installed...I tried some piping along the edge...kinda like it.
The interior is starting to look like a camper!
04-23-2012, 05:50 PM
#502
1959 17' Pacer
Long Beach
Oh very nice combo with the darker floors. What width are those boards? I like them a lot.
04-24-2012, 01:55 PM
#503
Austin
I like that floor-to-wall trim, is it the rubber edge molding that's designed to go between countertops and the wall? That's what it looks like to me, very clean, looks good.
04-25-2012, 07:23 AM
#504
Central
, Mississippi
The flooring is from Lumber Liquidators, a Cherry Laminate, 8" wide (4" wide pattern) x 47.5" long, 12mm thick. It was priced right and claims to be water resistant...dunno what it's made from but it is HARD! The small amout of cutting that I had to do completely wore out a new bandsaw blade...sparks flew every once in a while. I bought 12 boxes and have 3+ left over...humm...gotta check their restocking policy
You nailed it...ivory colored from one of my favorite suppliers...VTS! I am laying a bead of sealant at the edge of the floor and will use the edging where ever the joint is visible.
04-25-2012, 02:59 PM
#505
Central
, Mississippi
Originally Posted by rumrunner
The honey-do's never end do they? Btw where did you get the 12 volt panel, I really like the look of that?
tim
I finally remembered to look it up...I bought it from McMaster-Carr, part number 5183T12, $54.04
05-02-2012, 05:01 PM
#506
Central
, Mississippi
Further we go down the bottomless hole...a new 'toy' arrived today
05-02-2012, 05:25 PM
#507
Hollis
, New Hampshire
No bragging about new toys unless you post pictures of you using it!
05-03-2012, 09:30 AM
#508
1991 34' Limited
Wichita
, Kansas
Vernon,
That Cyclo Polisher is one cool tool! When you get all done with this polishing, your Dolly will be so bright that it should be plackarded "Warning, Eye Protection Required".
05-03-2012, 09:45 AM
#509
Tool Hoarder
West
The floor looks great, very exciting! What kind of piping did you use?
05-03-2012, 09:13 PM
#510
Central
, Mississippi
i did try it out tonight...after fighting for :30 with a power outage at the shed (dang ants)...it didn't take much effort to remove the lines and clouds using a liquid white rouge. More results to follow...I hope Mrs doesnt find out I used her sweat pants for the polishing bonnett
Originally Posted by Steve Bryant
Vernon,
Well I'm fully prepped for that...I still have the wrap around shades from eye surgery...Kinda makes me look like an old fan of Richard Petty...
The piping is from VTS, meant to use at the countertop/wall joint...I will use it where ever the floor-wall joint is visible (about 12" with my current floorplan!)
05-05-2012, 03:47 PM
#511
Central
, Mississippi
....I hope Mrs doesnt find out I used her sweat pants for the polishing bonnett  .....
Thanks OK sweetie, I used your razor this morning to shave my legs
05-06-2012, 04:58 PM
#512
Central
, Mississippi
Still working on the %@&*^$!!! pool...the new skimmer split so out it came again.
The Mrs picked out the bed/bath divider curtians...Hobby Lobby has some pretty cool stuff!
I did get Dolly's roof painted. Instead of removing the silicone from every rivet and every inch of seam and every vent and then resealing with vulcum...I used a roof sealing paint from Lowes. Of course I now have to tape off and polish up to the white area...
Of course I had to play with the cyclo...the entire curb side has a pass with white rouge.
Back to work at the office tomorrow with a 1/2 shaved face...
05-13-2012, 04:01 PM
#513
Gulfport
, Mississippi
HiHo, every one of your projects are looking great! Hey, in your spare time you can head south & I'll put all my 'Stream projects in a line!  I picked up a '55 Flying Cloud Whale Tail a few weeks ago & of course it needs a shell off!
05-14-2012, 01:56 PM
#514
Central
, Mississippi
a 55 FC Whale Tail? Cool!...just what you needed, another project, right?
05-14-2012, 08:27 PM
#515
Central
, Mississippi
Window glass tonight! All of the Mrs's hard work on the window frames made tonight easy...
VTS Butyl and gray glazing strips made the job super easy...
One point for future reference, 3/32 was the original glass thickness...and it's unavailable in my area. 1/8 glass works just fine!
05-15-2012, 05:52 AM
#516
1964 17' Bambi II
Schererville
, Indiana
Was all your glass broken, or did you just repair a few? You're right....Mrs. HiHo got the raw end of that deal! The window repair was a nice, rewarding project. Your trailer is almost finished! Looks great!
Becky
1964 Bambi II
1988 Avion 32S
05-15-2012, 09:55 AM
#517
Central
, Mississippi
2 of those were plexiglass and the 3rd had the glass glued to the frame. The glue was thinner than the original mastic so the glazing strips didn't stay in the slots. We had to break the glass to remove it. I'm hoping all of the other windows are repairable, it looks like they are in good shape, just need to replace the gray glazing plastic.
We have spent some time with a brass wire wheel in a drill, cleaning the openers and latches for these 3 windows. We still need to remove the fossizlized bulb seals in the frames and install new ones.
Progress has slowed because of camping trips and other weekend activities. These windows were the last "must get done" items before Dolly's Big Memorial Day outing!
05-16-2012, 03:39 AM
#518
Western
, Massachusetts
Enjoy the Memorial Day outing. It's well deserved for both you and Mrs HiHo.
Good way to recharge the batteries and rebuild the motivation!
John
05-17-2012, 11:55 AM
#519
Central
, Mississippi
Dolly's 1st coming out event!
Even though I've stayed overnight at hunting camp, I really didn't consider that her first real trip. A one-nighter at the Ameristar Casino with full hookups counts as her first official trip.
The 100 yard polish looks ok...still need to do some more detail work. Redneck Airconditioning works but looks ugly. No running water but the cable system works. Black system is functional. I hope nobody notices the curtians are all different (and I hope Mrs doesn't notice that most of the good towels are missing from home)
05-17-2012, 07:01 PM
#520
Always learning
1972 29' Ambassador
1962 19' Globetrotter
1951 21' Flying Cloud
Central
Looks great Vernon! Enjoy your outing.
Lance
