Old 07-15-2011, 07:18 PM   #221
Central , Mississippi
Originally Posted by REDNAX View Post
I'm using some 3m version from Home Depot for the glue...sticks like crazy after a few seconds so ya' cant lolly-gag around...
3M Spray 77 as made famous in the Blues Brothers movie? (Also affectionately known as "Gorilla Snot").
Wow...I had to look that one up!
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie(RIP) -
A honkin' long 34' named AlumaTherapy https://www.airforums.com/forums/f20...num-54749.html
and a 26' '63 Overlander, Dolly https://www.airforums.com/forums/f10...ome-71609.html
Old 07-16-2011, 07:39 PM   #222
Prodex...this stuff is wierd...my laser heat-o-meter says the 1st layer of prodex has the same skin temp as the bare aluminum... BUT...my hand can't stay on the bare skin (too hot) while just a few inches away, the prodex is tolerable...AND the AC kept the inside cool today...
Anyway...layer 1 is almost complete...layer two will take a while...electrical is gotta be done first...
Mrs. HiHo started de-silicon'ing today...lot's of P.O. sealing attempts...
Oh, yes...3M 77....is good glue
Name:	Prodex layer one.jpg
Old 07-17-2011, 05:09 PM   #223
Look Ma'...No Cleco's!!!
Mrs HiHo helped and we got all of the curb side rivets installed. Remaining are the street side wheel well and a few on the front.
I still have to install the rear hold down structure...just kinda dragging on that one. I need to cut a long 2" wide chunk of thick aluminum to go beneath the floor, then install 6 - 8 bolts. Not a very hard job, I just can't seem to get motivated to do it.
Dolly now has 110v wiring run for all of the main circuits, 6 total counting the main feed. A few misc wires...cable TV...charge back line...and she's not far from the second layer of Prodex...then comes endcaps and skins...
Name:	No Clecos.jpg
Old 07-18-2011, 09:02 AM   #224
Newbie
1977 31' Sovereign
Southfield , Michigan
Nice job, good to see you making progress I can't wait to see the finished product.
MS03 is offline   Reply With Quote
Old 07-18-2011, 05:54 PM   #225
Have you ever had a GRRRRRRR day? That's what mine was...
I need 50+ feet of #10 stranded....minimum available in my area...500'
I head to Fastenal to get my order...remember I haven't hit a home run with orders from the local store...6' of hinge and a 12 tube case of Trem Pro 625...all ordered special for me...
Well the 'case' is 30 tubes (i'm sure I said a 12 tube case and 100% sure that they didn't correct me and say a case is 30 tubes...we had a conversation) and the hinge is bent and twisted like a pretzel...
So...since I ordered it, it's mine (they did offer to 'try again' on the hinge)...no thanks, I'll take my stuff and this is the last time you will see me.
So if anyone is wondering why TremPro 635 is in short supply...I cornered the market...and will be offering it to fellow forum members in the classified section...
Name:	Bent Hinge.jpg
ID:	135238   Click image for larger version
Name:	Trem pro for years.jpg
Old 07-21-2011, 08:36 PM   #226
This forum is cool and the members are second to none. I didn't even have the chance to post the excess tubes of Trempro on the classified section before members contacted me and picked up the excess from my order.
Thanks y'all!
Old 08-06-2011, 01:49 PM   #227
Some progress today...step 1) Discover that a Honda 2000 WILL run the small window airconditioner hanging thru the water heater hole...
I've been worrying about all of the pop rivets that are still showing on the interior. When removing the interior skins, most of the rivets simply sheared off the head, leaving the stem protruding. I bought a 'flap' wheel and put it on an angle grinder...quick work removing the stems
All of the wiring is now installed...I have to tape the edges of the first layer of Prodex...second layer is next, then comes the interior panels!
Crappy iphone photos...
Name:	Flap wheel.jpg
ID:	136891   Click image for larger version
Name:	Port Wiring.jpg
Name:	Starboard wires.jpg
Old 08-07-2011, 12:22 PM   #228
Newbie
1977 31' Sovereign
Wink
Good to see you are making progress
Old 08-07-2011, 06:22 PM   #229
Becky B.'s Avatar
1964 17' Bambi II
Schererville , Indiana
I'm glad you're ahead of me....looks great & I can follow your leads! Wish I could read your notes to see if mine are in line with yours! Great to see your progress. Keep it up!
Becky
1964 Bambi II
1988 Avion 32S
Becky B. is offline   Reply With Quote
Old 08-07-2011, 08:45 PM   #230
Notes? Uh oh....I was supposed to make notes? (flash backs to junior high school)
Old 08-07-2011, 09:14 PM   #231
Becky B.'s Avatar
1964 17' Bambi II
In case you forgot, they're hanging on your wall!
Becky
1964 Bambi II
1988 Avion 32S
Old 08-08-2011, 11:55 AM   #232
1958 18' "Footer"
Manchester , Lancs
Great thread for a new member to read through, and what a great job you are doing Keep up the good work
Robbhp is offline   Reply With Quote
Old 08-09-2011, 09:07 PM   #233
Heck, I just hung that stuff for the photo...who needs notes?...what were we discussing?
Really...that is the one thing that I do worry about...imagine getting new interior skins installed, then remembering you needed another outlet!
Old 08-15-2011, 01:45 PM   #234
MarkR's Avatar
1951 21' Flying Cloud
1960 24' Tradewind
Folsom , California
Images: 12
. . . Really...that is the one thing that I do worry about...imagine getting new interior skins installed, then remembering you needed another outlet!
you just nailed the reason why it has taken me an embarrassingly long time to get my trailer on the road . . .
(I take that back, that's just an "additional" reason why - not "thee" reason why)
Aluminumbskull with Led Balloon in Drag
Birch Plywood and Aluminum go together like
Peanut Butter and Chocolate
MarkR is offline   Reply With Quote
Old 08-17-2011, 11:18 AM   #235
I keep coming up with new reasons why I don't make steady progress...
When I get really busy at work, I have a tendency to want to goof off more in my spare time - thus camping takes up the weekends.
Old 08-17-2011, 12:14 PM   #236
SilverHoot's Avatar
1967 24' Tradewind
Greenville , South Carolina
That sure looks familiar! Great work!
SilverHoot is offline   Reply With Quote
Old 08-18-2011, 04:38 PM   #237
Overlander & Sea's Avatar
Gulfport , Mississippi
Images: 35
Hey Vernon, the work is lookin' great and I think it's going fast!! Keep the photos coming!
....I know, I know, I need to get back on my '63 GT. I been over a year since we worked on it.
Rick--Foley RV Center www.airstreamofmississippi.com
WBCCI #9275 TAC #MS-5 AIR #11800
Overlander & Sea is offline   Reply With Quote
Old 09-10-2011, 11:37 AM   #238
Finally some more progress. The temps have moderated and we are home this weekend so this morning I tackled the AVI door. 1 conclusion...I hate vulcum. Combine it with rivets and it's an unholy evil mess.
I also drilled the wire holes for the front marker lights.
Name:	AVI door 1.jpg
ID:	139870   Click image for larger version
Name:	AVI door 2.jpg
Old 09-10-2011, 04:07 PM   #239
Ive been draggin out this task for a while...I'm not a huge fan of strippin paint but the time has come to tackle the rear cap. 1/2 way done and I've removed a couple of pounds of latex.
Orange Stripper to the rescue again!
Name:	Rear cap latexed.jpg
ID:	139884   Click image for larger version
Name:	Rear cap  half off.jpg
Old 09-11-2011, 05:18 PM   #240
How do small tasks that seem to take all day often have nothing to show?
Riveted the last of the shell-to-chassis spots, installed the rear-hold-down straps and bolts and installed the awning rail.
Let me check - yup, still hate vulcum....
Name:	Rear Hold down rivets.jpg
ID:	139935   Click image for larger version
1963, overlander, restoration
