Old 09-03-2005, 08:04 PM   #281
uwe
418
uwe's Avatar
2007 25' Safari FB SE
1958 22' Flying Cloud
1974 29' Ambassador
Yucca Valley , California
Images: 41
I feel bad for being so excited about my trailer, with all the misery down south in Katrina's aftermath.
Uwe
www.area63productions.com
Old 09-03-2005, 08:07 PM   #282
Just a member
thenewkid64's Avatar
1978 28' Argosy 28
Tampa Bay , Florida
Images: 21
Originally Posted by uwe
What about these:
Not trying to be stubborn, just imagining appliance shuddering down the road, copper line having little or no give, and all the while the stresses end up at the connections. Can't be that good. I had to redo a bunch of connections on the 71 Tradewind.
Are those in the link above legal?
I dunno about legal, but they should do the job. I would stub the hard line thru the floor and tap into it there with the flex line. I would also add a shut off valve on the outside before you cone up thru the belly pan and floor.
Brett G
WBCCI #5501 AIR # 49
1978 Argosy 28 foot Motorhome
Old 09-03-2005, 08:12 PM   #283
uwe
418
uwe's Avatar
1974 29' Ambassador
Images: 41
Tub
Almost forgot,
The tub got done, too. They spent over 3 hours on it, prepping, priming, filling, sanding, priming agin, then several coats of finish coating.
Once it's installed, they will come back and wetsand/buff it. Should be really nice. It's slightly grainy right now, but definitely nice.
Uwe
Old 09-03-2005, 08:16 PM   #284
uwe
418
uwe's Avatar
1974 29' Ambassador
Images: 41
I want to insure this nightmare once it's done. Too much time and money in it to risk losing it to misfortune.
Hence, my quest for a legal installation.
So far that I know, all but the final connections to the applicane must be made outside the living space of the coach. This means I'd have to run the flex out through the floor, to a shutoff valve right under the belly pan.
Thanks for the shutof valve idea, Brett.
Uwe
Old 09-03-2005, 08:19 PM   #285
uwe
418
uwe's Avatar
1974 29' Ambassador
Images: 41
New Wheels!
My tires and wheels came in yesterday as well.
4 Marathons, and 4 alloy wheels. I will get a 5th wheel for a spare, once my budget allows.
Uwe
Old 09-03-2005, 08:30 PM   #286
fastrob's Avatar
1976 25' Tradewind
. , AZ to Maine
Flex Lines / Window a/c?
Uwe,
Your construction is immaculate.
I like the metal flex line like we have on our gas stove at home.
There is nothing quite like a gas explosion in a metal can.
Easily purchased at a gas supplier.
Is your a/c a window unit? I like your clean roof ideas.
In another thread the mention of cold feet turned me off somewhat.
An air diffuser on the ceiling and ductwork to the peak would be a challenge.
Hot air rises, cold air falls, pick up hot, drop down cold.
Still have trouble with the flow of air, great that you share with us.
A friend dealt in used Airstreams, he never used a spare, they work on three tires, he used a 4 cyl Japanese truck to haul them.
Robert
fastrob is offline   Reply With Quote
Old 09-03-2005, 08:34 PM   #287
Addicted to Aluminum
A-Merry-Can's Avatar
1959 18' "Footer"
1964 24' Tradewind
1954 29' Liner
Woodstock , Georgia
wow! you've made a lot of progress, man. i can't wait until the projects on mine are one day jobs, rather than "i gotta get this done before the rain comes again" type things.
one day!
jordan
there's always room for one more!
A-Merry-Can is offline   Reply With Quote
Old 09-03-2005, 08:38 PM   #288
uwe
418
uwe's Avatar
1974 29' Ambassador
Images: 41
Originally Posted by Fast Rob
Uwe,
Robert
Robert,
Yes, it is a window unit. The biggest and baddest one that still runs on 120V.
I modded it to have 2 4in outlets. You can see one of them in the pictures below. There is plenty room for flexible, insulated ducting to be ran through the walls and overhead bins to bring the air up to roof level. The a/c is efficient enough to push the air through 10-15ft of ducts, without a problem. I did a dry run before permanently installing the beast. I'll post more as I build out the interior. Stay tuned.
Uwe
Old 09-03-2005, 08:41 PM   #289
uwe
418
uwe's Avatar
1974 29' Ambassador
Images: 41
one day!
jordan
It sort of creeps up on you. All of sudden, it's time to put away the air tools and start looking around for the next step in the queue.
I can attest to the fact that once the burns from welding and wounds from metal work have healed, the itching from removing old insulation has subsided, the fear of dying from rot and mildew has eased, this is actually great fun!
Uwe
Old 09-03-2005, 10:55 PM   #290
pinkflamingoes's Avatar
1967 24' Tradewind
Alameda , California
Images: 38
Send a message via AIM to pinkflamingoes Send a message via Yahoo to pinkflamingoes
I think everybody feels bad, just getting on with their lives. Just remember you're concentrating on what's important in life by finishing this trailer, because a disaster can befall any of us.
You're making so much progress and I've been going so slowly! Tomorrow I'm going back to work on the windows. Keep up the motivation for the rest of us!
"Let's look Death in the face and say, 'Whatever man.'"
~ Hurley
ingrid
1967 24' Tradewind #19104 ~ Forums #4449
pinkflamingoes is offline   Reply With Quote
Old 09-04-2005, 09:10 AM   #291
Ken J's Avatar
1956 22' Flying Cloud
Durango , Colorado
Images: 14
Uwe
I'm not sure about the rubber lines as those in your link. My understanding is the residential metal ones are a no no. I don't know if the rubber are legal. However, since you have to have all connections outside the belly, I would be concerned about the rubber rubbing against the belly sheet metal. I if you make the hole big enough, you invite the mice.... My (again its my understanding from reading this stuff for about 8 years) understanding is you want to use flair joints at the appliance. The worst case for that type of fitting is you have to tighen them every once in a while.
I agree with Brett on the valves - its what I plan to do and is what I had on the Tradewind.
A quick check for gas leaks is to run the stove (as in light it). Then shut off the stove and the valve at the tank. Wait 15 minutes - then light the stove (don't turn the valve on the main tank) - when you light it, it will run a bit before it goes out. If it doesn't - you have a leak.
Ken
1956 Flying Cloud
Founder :
Four Corners Unit
Albuquerque National Balloon Fiesta
Rally
Vintage Trailer Academy - Formerly the original
restoration rally
Ken J is offline   Reply With Quote
Old 09-04-2005, 09:10 AM   #292
Ken J's Avatar
Durango , Colorado
Images: 14
Those wheels look fantastic!!!!
1956 Flying Cloud
Founder :
Four Corners Unit
Rally
restoration rally
Old 09-04-2005, 09:25 AM   #293
uwe
418
uwe's Avatar
1974 29' Ambassador
Images: 41
Thanks, Ken. I will mount and balance them on Tuesday, then I can let you know how they fit.
From the looks of it, they should be perfect, as they are 15x6, zero offset.
Just like a factory wheel.
Uwe
Old 09-04-2005, 09:33 AM   #294
uwe
418
uwe's Avatar
1974 29' Ambassador
Images: 41
Uwe
Ken
I can run solid copper to all the appliances but the refrigerator. You're right, it's not that big of a deal to tighten some fitting every once in a blue moon.
I used to drip soapy water onto the fittings, and watch for bubbles. Someone told me this would be a good leak detection method.
My refrigerator is a hardwood slides, so I can easily pull it forward for service. I believe I already mentioned that I did not want to cut the skin for an access panel, so I plan on simply making the side wall that covers the fridge removeable towards the entry door space. This means that the fridge's LP supply line must be somewhat flexible, to facilitate the movement of the unit in case of a service need.
What size copper is the main supply line, typically? What size are the individual appliance feeds?
Uwe
Old 09-04-2005, 09:50 AM   #295
Ken J's Avatar
Durango , Colorado
Images: 14
Uwe
To solve the refrig problem, you can make a big circle with the copper so that it will allow you to pull the frig out enough to take the gas line off.
Yea soap is what I use on new connections.
Now you are taxing my brain on the size - 3/8" to appliances and 1/2" main supply line from the tanks??? Now I wish I had the Tradewind to measure. I'm sure someone will know here.
Did you catch my post on the special gas rated copper?
Ken
1956 Flying Cloud
Founder :
Four Corners Unit
Rally
restoration rally
Old 09-04-2005, 05:22 PM   #296
greg176's Avatar
Gabriola Island , British Columbia
I am soon at the point where I have to decide on where to place the batteries.Looking at page 11 of this thread it appears that there may still be room for a battery box on the tongue.I may also place batteries under front dinette in vented box.I also like the idea of putting them inboard of the right wheel tub.Been thinking this one out for a year now and still not decided.
greg176 is offline   Reply With Quote
Old 09-04-2005, 06:29 PM   #297
Ken J's Avatar
Durango , Colorado
Images: 14
In my view I would put the batteries anywhere forward of the wheel well. I plan to put as little weight in the rear as possible. I also plan to put mine on the tongue (just using one battery) as it is forward and in the center of the trailer.........
Ken J.
1956 Flying Cloud
Founder :
Four Corners Unit
Rally
restoration rally
Old 09-04-2005, 07:16 PM   #298
1959 18' "Footer"
1964 24' Tradewind
1954 29' Liner
Woodstock , Georgia
my original plan was to have the batteries slide out (on a sliding shelf) of the rear access hatch on my 18 footer, how many batteries do i need to allow for? i was planning on 2. is this significant enough (weight-wise) to make me locate all thsi junk up front? i do understand the need for a vented box, however. just not sure about all the balance issues.
one advantage, i guess in reloacing everything up front is i could seal up that rear hatch and make the back end really smooth and clean.
jordan
Old 09-04-2005, 09:04 PM   #299
uwe
418
uwe's Avatar
1974 29' Ambassador
Images: 41
My trailer had the 10gal water heater immediately behind the rear axle, under the bed. There was also a galvanized fresh water tank under the bed, right above the axles. ( Gone!) I moved the water heater to the front, where the furnace used to reside. I placed the a/c where the water heater used to be. Opposite the galley is the refrigerator, and opposite the a/c I placed the two batteries. Both these items are as close to the wheel well as possible. I di drun a 4ga battery cable to the tongue, in case it becomes necessary to add tongue weight by moving the batteries there. However, I am confident that this will be ok. A trip to the scles once finished, will tell.
Also, I am going to install a spare tire in teh spot right behind the tanks. In due time...
I have 50 or so gal of fresh water ahead of the front axle, at sub floor level.
My plan should give good weight balance, especially with a better than half full water tank.
The a/c weighs about 70lbs, both batteries weigh about 70 lbs also. I am unsure of how much the refrigerator will weigh, or the galley etc. But have a feeling that once it's all ready to go and loaded with food, it should be balanced nicely side to side, and have the necessary tongue weight to make it a nice towing trailer. Or so I think.......
Uwe
Old 09-04-2005, 09:26 PM   #300
greg176's Avatar
I may just run wires under front left window and leave long enough to cover placing batteries from tongue to under sink.I could then use them to adjust tongue weight.
