Old 01-03-2013, 05:42 PM   #141
reinergirl's Avatar
Hollis , New Hampshire
As a side note, Colin has typically used Reflectix in the past. I wanted him to use Prodex and supplied it
( I've yet to hear if one is easier to work with than the other!)
The third picture is the axle modification.
Prodex installed & fiberglass insulation installation in progress.
Axle mounting plates modified to suit mounting bracket & 1/4” lift required due to grey tank installation
Colin commented: Axle brackets are not available that suit the original bolt pattern, so some drilling would be necessary, however on this trailer, one of the axles lined up with a crossmember & as the axle tube is "pre cambered", the arc of the axle interfered with the crossmember, so Airstream just cut the lower flange off the crossmember. We added an angle iron to reinforce the crossmember to help support the grey tank. The axles then needed a 1/4" shim added to them so the arc wouldn't hit the new angle iron on the crossmember. This is why we needed to add material to the mounting plates.
Final grey tank installation.
Lower fridge vent intake.
Prodex encompassing grey tanks.
reinergirl is offline   Reply With Quote
Old 01-03-2013, 05:49 PM   #142
Central , Mississippi
Thats really cool. There are some interesting differences between your OH trailer and my CA. I already had the extra strap in the step area to support the ply joint. My axle was NOT over the crossmember...ALSO my fridge doesn't vent thru the floor.
Thanks for all of the photos
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie(RIP) -
A honkin' long 34' named AlumaTherapy https://www.airforums.com/forums/f20...num-54749.html
and a 26' '63 Overlander, Dolly https://www.airforums.com/forums/f10...ome-71609.html
Old 01-04-2013, 07:19 AM   #143
reinergirl's Avatar
Hey HiHo!
Yeah there are lots of differences, I guess 1964 was the first year that they pushed standardization. I have a completely different roof antenna and our main door within a door hinges are different too. As I remember you have straps, I just have regular hinges.
I originally did not have a vent thru the floor, Colin said the newer propane units work better that way so it was something that was added.
Looks to me you're ready to enjoy and I'm just getting started! Lol. Didn't you start after me?
Old 01-04-2013, 07:54 AM   #144
KCN
KCN's Avatar
Victor , Idaho
The pictures are awesome. You and Colin are really helping me by posting your progress - this way I can take my iPad in with me to the supply guys and say "See? THIS thing?" I went to school across the lake from Plattsburgh...wish I could get my trailer up there but the forums will have to suffice.
KCN
KCN is offline   Reply With Quote
Old 01-04-2013, 03:29 PM   #145
reinergirl's Avatar
KCN
Thanks KCN,
That was the whole point of doing this! I'm a very visual person and for example, it's one thing to talk about how/where gray tanks go in, its another to be able to actually visualize it.
I am very grateful to Colin for allowing/encouraging me to post these pictures. I'm guessing that by doing so he is helping more than a few people like you, who may not have the time/money/access to a professional restorer.
Old 01-04-2013, 06:03 PM   #146
reinergirl's Avatar
Bellypan time!
Ta da!!! It's time for the Bellypan!
Bellypan side fabrication
Bellypan fabrication
Endcaps fabricated for step outriggers.
Rear street side bellypan corner fabrication.
Rear curbside corner & side bellypan fabrication.
More bellypan fabrication.
One more picture to come.....
Old 01-04-2013, 06:06 PM   #147
reinergirl's Avatar
Bellypan side with fridge vent intake. The final wheel well trim will be done after the body is re-installed.
Old 01-04-2013, 06:51 PM   #148
2vets's Avatar
1960 24' Tradewind
St. Albans , Vermont
Wow! Everything looks so new and shiny!
Don't look at the light!" .. "I can't help it, it's so beautiful" (A Bug's Life)
https://1960airstreamtradewind.blogspot.com
Love. You can learn all the math in the 'verse... but you take a boat in the air that you don't love... she'll shake you off just as sure as the turn of the worlds.
2vets is offline   Reply With Quote
Old 01-05-2013, 05:28 PM   #149
reinergirl's Avatar
Colin just mentioned Moonraker on the latest episode of The VAP. She's famous now!
Old 01-05-2013, 06:09 PM   #150
reinergirl's Avatar
Yea.
Old 01-05-2013, 08:03 PM   #151
desertair27's Avatar
1960 26' Overlander
1963 24' Tradewind
El Paso , Texas
Images: 32
I was looking for the like button not realizing I wasn't on Facebook! Definitely cool up hear about your trailer on the VAP!
Sure miss Frank and Rob Baker on the VAP.
desertair27 is offline   Reply With Quote
Old 01-07-2013, 01:09 PM   #152
worldinchaos's Avatar
1959 17' Pacer
Long Beach , California
Golly I wish my bellypan looked that smooth. Jealous....
- Peter (and Marie)
TAC CA-15
1959 Pacer 18' Renovation - Knight in Shining Armor
Our Adventure Blog - Documenting our backpacking, hiking, camping, and Airstreaming
(still updating, haven't gotten to the Airstream trips yet)
worldinchaos is offline   Reply With Quote
Old 01-08-2013, 03:14 PM   #153
pullswitha40's Avatar
ogden , Utah
Love these threads......lots of photos please!!!
pullswitha40 is offline   Reply With Quote
Old 01-09-2013, 07:27 PM   #154
reinergirl's Avatar
More bellypan and gray tank plumbing....
Grey tank plumbing & dump valve assembly.
Bellypan fabricatio
n
Old 01-09-2013, 07:41 PM   #155
reinergirl's Avatar
Moonraker has landed!
7 way “whip” installed through bellypan & “C” channel at base of front wall.
Completed bellypan with axles installed.
Grey valve assembly installed.
Axles & new wheels installed.
Flipping the rebuilt chassis over for the final time.
Old 01-09-2013, 07:49 PM   #156
reinergirl's Avatar
Body in position to have the rebuilt chassis positioned below.
Installing rebuilt chassis
Body lowered onto rebuilt chassis & final positioning being done.
Preliminary positioning of body on rebuilt chassis.
YIPPEE!!
Old 01-10-2013, 07:24 AM   #157
65CV's Avatar
Western , Massachusetts
Touchdown!
Congratulations.
John
65CV is offline   Reply With Quote
Old 01-10-2013, 09:12 AM   #158
ogden , Utah
Dido dat
Old 01-10-2013, 05:36 PM   #159
Heck, I'm tickled FOR you!!!!
Old 01-10-2013, 06:22 PM   #160
reinergirl's Avatar
Well, it was sweet while it lasted! Talked to Colin today and they had a heck of a time getting the shell on, and it's not there yet. Turns out that Moonraker originally had been put on cockeyed (last trailer in the line on a Friday afternoon?)
In order for her to be straight and true they had to trim the bottom edge of the shell on the curbside up to 3/4 of an inch! Which of course means redrilling for all the rivets on the c channel. I think they even had to cut the wheel well cutout .... Of course this is the side that was NOT being replaced. The other side is getting the big long panel replaced due to a wheel blowout. Figures huh?
I remember seeing some ribs that were jury rigged when we stripped the interior, guess I know what that was about now!. Of course this means that the bulkheads and interior skins are going to be shorter too. Ah well.
More pictures tonight I hope!
Thanks all!
NEEDED: Two front windows for '71 Overlander jesse_kevon Windows, Doors, Locks & Vents 4 05-30-2015 09:26 AM
Need Door for 1961 Overlander BentMetal 1960 - 1964 Overlander 9 07-28-2011 04:36 PM
Need Refrigerator Compartment Door for 1972 Overlander jazz1945 Exterior Storage Compartments & Access Doors 1 05-30-2011 02:50 PM
My 1963 Overlander Exterior Corle0ne Cleaning, Stripping & Polishing 3 04-29-2011 10:25 AM
should i buy a new toilet for my 1963 overlander? harrison Sinks, Showers & Toilets 3 04-26-2011 04:42 AM
