G, thanks for the reply.
We have not YET located any
12V breakers will continue the search for them as we know they are in here somewhere. We DID however get the
12V back working.
We started with the disconnect from the battery option, waited about an hour, reconnected the battery but
12V did NOT reset. We then tested the battery, in case that was our problem and it still showed 25 percent. We put the battery on charger.
Meanwhile we opened the flap under the curbside corner of the belly pan. Lots of wiring tangles, a few acorns but no 12V breaker. DH felt around inside and I took photos (photos not good enough to post) and we didn't locate breaker.
Put the fully charged battery back in and 12V is back working. So possibly while testing the capped off wires we drained the battery enough to make it not be able to power the trailers 12V.
Photographs show the battery box (I refer to it as a flower box) which is teeny an barely fits our optima(s) batteries, maybe that's why everybody opts to put their new ones inside. Also a photo of the wire tangles. NOTE the knots in the red wires.
Digression:
I have spent a lot of time over the years reading AirForums. Lots of restoration threads and the other material too. I go back to the vintage years Threads and read people's builds and questions as they pertain to our vintages also. Some of the information sinks in some of it is stashed away for later times but I have learned or at least have been exposed to a lot of info over the years. So yesterday morning while rereading Goranson's 2011 started thread about his ATWC Safari he talks specifically about red wires under the front side of the belly pan and the Knots in them. Another poster answers his knot thoughts and links to it. The link still worked and the lightbulbs went off for me. Those knots actually mean something. Silly me, when I was looking at the tangled wire mess I thought "why would somebody leave those knots in the red wires, I'll undo those when we get around to it". Not so fast there. Thank you very much Goranson. Yes I have been reading that thread for a long time but seeing as how we didn't join AirForums until 2013 I likely hadn't read back to the very start of that thread.
