Old 01-31-2014, 12:31 PM   #101
1972 21' Globetrotter
Wylie , Texas
I'm embarrassed to say at Ross. But I'm sure amazon has the newest and improved. Any luck with Trident?
rippie is offline   Reply With Quote
Old 02-02-2014, 09:31 PM   #102
Cardinal283's Avatar
Dallas , Texas
Don't fall into the "fallacy of origins". Just because something's origin isn't what one may want doesn't rule out its validity. If it works it works. Regardless of where it came from. ; )
Cardinal283 is offline   Reply With Quote
Old 02-03-2014, 05:42 PM   #103
Dallas , Texas
Ok guys. I'm in the final steps of nailing down my floor plan and systems layout. Let me know what you guys think and if you see anything I might be missing or failed to consider.
Floor plan:
Fresh water system:
The pump and one way check valve will go under the couch/table
Electrical:
I haven't decided the best location for the electrical panel. My initial thought was under the cushion on the couch.
I tried to get plenty of 110v outlets and I even threw one in at the foot of the bed for the electric blanket, Vernon. ; ) the two outlets that look like they are on the floor are actually down on a wall/cabinet nearer to the baseboard for plugging in a small space heater if needed.
Old 02-04-2014, 02:16 PM   #104
Hittenstiehl's Avatar
1962 28' Ambassador
1961 19' Globetrotter
Mesa , Arizona
Very nice use of the colored diagrams. It really helps to visualize where things are going. A 26 Overlander may be in our future so thanks for the inspiration.
Hittenstiehl
Hittenstiehl is offline   Reply With Quote
Old 02-04-2014, 04:23 PM   #105
65CV's Avatar
Western , Massachusetts
Looks very livable. A couple of thoughts:
- 12 volt receptacles
- Curtain from Dresser to Shower will give lots of privacy and extra quiet for naps
- if the 120v inlet is that far forward, you'll need a long cord in many parks
- I got a lot from mocking up the dinette in cardboard. Small tweaks matter.
- consider 2 tables. 1 for party mode, a long one to the window for just 2-4
- can you explain A/C ducting?
John
65CV is offline   Reply With Quote
Old 02-04-2014, 06:32 PM   #106
Dallas , Texas
Originally Posted by 65CV View Post
Looks very livable. A couple of thoughts: - 12 volt receptacles - Curtain from Dresser to Shower will give lots of privacy and extra quiet for naps - if the 120v inlet is that far forward, you'll need a long cord in many parks - I got a lot from mocking up the dinette in cardboard. Small tweaks matter. - consider 2 tables. 1 for party mode, a long one to the window for just 2-4 - can you explain A/C ducting? John
John,
Regarding the duct I plan to do something along this line to make sure the air from the AC gets to the front and, most importantly, back of the trailer where the bed is. A very thin but wide AC duct along the ceiling that moves the air to the ends of the trailer with a return vent in the center.
For the privacy curtain I am considering a sliding door that slides into the wall that separates the shower from the kitchen. I wonder if that's overkill?
I can locate the shore power inlet anywhere on the street side and wire it to the control panel. I am having a hard time thinking of an alternate location that doesn't cost me drawer space.
Please explain what you mean by a cardboard mock up... Are you talking a full sized mock up? I've been really concerned about getting the ergonomics of the dinette correct. This is a place that we will be spending a lot of time doing paperwork, eating dinner, and relaxing. I want to get that part right.
Thanks!
Toby.
Old 02-04-2014, 07:13 PM   #107
65CV's Avatar
Toby,
There are a couple of pictures here, see post 347. Yup, I kept some of the boxes from the fridge and AC to build the prototype.
See the previous page for a good discussion of dinette design. Ours is very different -- we did the A/C on the floor at the end of the galley. You'll see the pics there. It is installed, tested and VERY quiet but will require a 12v fan to circulate air within the trailer. I'm a light sleeper and couldn't sleep with the AC on the roof.
I'll be digging out of another storm tomorrow rather than working on the Overlander.
John
Old 02-05-2014, 05:32 PM   #108
Dallas , Texas
I've been tossing the idea of putting the AC on the floor like that, but I have had a few reservations about doing it. For it to cool optimally it would need to be ducted up to the ceiling instead of letting the cool air out low to the ground. Even with fans you wouldn't get proper air circulation with the supply duct low. Ideally for an AC only system (no heater) both the return air and the supply air vents should be high for maximum cooling so that the supply is high and the cool air falls. The return duct placed high so that it draws in the hot air and cools it instead of drawing cool air off the floor. This will be especially important here in Texas where we hit 110 degrees on some days.
What have you experienced with your set up as far as cooling ability on hot days, John? I like the 12v fans you put in for extra air flow over the condenser coil. Do you have any pics of the cover you put on the outside?
Old 02-06-2014, 05:48 PM   #109
65CV's Avatar
My idea of a hot day is 90, not 110! In 90+ degrees, with no curtains on the windows, it was just holding 70s. With reflectix between the windows and screens, it was much better. Sorry, but I didn't get temps.
If you use regular curtains, with some open to the sun, I don't think a 12000 but A/C will do the trick in Texas, no matter where it is located.
You may want to ping utee94, who has a '63 Overlander not far from Austin. He may have more insight on AC in your weather.
In the summertime, we head to Vermont or Canada. I can't imagine your summers!
I don't have a current picture of the cover for the vent, but the original, unpolished one is in this thread, the first picture in post 20.
Old 02-07-2014, 05:28 PM   #110
Dallas , Texas
Yeah. Our summer can get pretty brutal. Add the triple digit temps with 90% humidity and the incessant sun over head and it gets really nasty. I've used my laser thermometer on the blacktop and it gets up to 150 degrees.
On a side note. While I haven't been working on the Armadillo as of late I have spent a little time inside it when it's cold out. I ran a little propane shop heater to take the chill off of the inside and I noticed some places that have water in the U channel. It runs onto the floor and makes little water streaks. I'm pretty sure I have all the leaks taped up with aluminum tape and this is condensation on the exterior skin (the interior lower skin is still off with no insulation). I understand that I have warm moist air touching a cold conductive surface. Hence the condensation. Once I get this insulated and have the inner skins back on is this still a common problem? Or will it try to condense on the inside of the inner skin instead?
Old 02-07-2014, 07:16 PM   #111
65CV's Avatar
150 is insane! I see why some put 2 a/c units in. I can't believe that a 12K but unit would work for you. Maybe a 15 or 18, if you can locate one.
On the heater, keep in mind that propane heaters put out a LOT of moisture. Every little propane molecule produces 4 molecules of water and 3 of CO2 -- if you have perfect combustion and no carbon monoxide.
In my experience, the moisture all condenses on the single pane windows. With good wall insulation, it doesn't condense there at all.
We always keep a window cracked an inch and a roof vent cracked about two inches to keep the moisture level down and to be sure we're safe from carbon monoxide. We never run the heater without a CO monitor running.
With enough fresh air, you can keep the moisture under control in a reasonably humid area. If it's really humid and cold, it's damp! That's when the electric heat comes in very hand.
Old 02-08-2014, 04:52 PM   #112
Dallas , Texas
What method did you use when insulating yours? I'm leaning toward double layered Prodex at the moment.
Old 02-08-2014, 07:17 PM   #113
65CV's Avatar
We used double layer Prodex, getting air space between layers by using strips of prodex. We glued vertical strips, then a full layer, then horizontal strips, then a full layer. It's all in my thread, with pics.
There's been a lot of work reported on this forum on different methods. After reading a bunch, I definitely concluded that the reflective insulation is much better if you plan to be in direct sunlight in warm weather -- especially as far south as you are!
If you haven't seen discussions about Prodex deals, keep an eye on insulation4less.com. They aren't user friendly, but do drop prices frequently. If you're not in a hurry, you'll be able to pick up a good deal. Some have hit 50% off. Two 48" rolls will do an Overlander with 2 layers on the walls, one on the floor and enough to make an insert between each window and screen. When not in use, ours has the Prodex window covers in place. It keeps the UV out well while reducing temperature swings.
Old 02-09-2014, 12:03 PM   #114
Dallas , Texas
I like that idea. You have an air gap between the exterior skin and the first layer of Prodex and then a second air gap between the first and second layer of Prodex. I will read over your thread and take some notes on installation.
I created an account on insulation4less and they send me emails for promotions. I'm not to the point of insulating yet but I'm getting ready for it. I'm hoping that before I am ready that they will have one of those 50% off sales. : )
Old 02-17-2014, 01:56 PM   #115
Dallas , Texas
I'm needing to buy a tool but I don't know the name of it. It's a sheet metal tool for breaking the edge of a piece of sheet metal over slightly to create a finished edge. I've seen them before I just don't know what it's called. It's a handle and it has rollers on it that produce the result shown in the pic. It can even do this around a curve such as around the top of the main door. Does anyone know what that tool is called or what the process of making this type of edge is called?
Old 02-17-2014, 02:17 PM   #116
truckasaurus's Avatar
1960 33' Custom
Athens , Georgia
EDGE ROLLING TOOL from Aircraft Spruce
truckasaurus is online now   Reply With Quote
Old 02-17-2014, 02:40 PM   #117
Central , Mississippi
Or if you are looking for an excuse to buy tools, this is what I use to make those edges.
http://www.eastwood.com/welders/bead-roller.html
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie(RIP) -
A honkin' long 34' named AlumaTherapy https://www.airforums.com/forums/f20...num-54749.html
and a 26' '63 Overlander, Dolly https://www.airforums.com/forums/f10...ome-71609.html
Old 02-17-2014, 02:42 PM   #118
Like this...
Old 02-17-2014, 04:06 PM   #119
Dallas , Texas
Originally Posted by HiHoAgRV View Post
Or if you are looking for an excuse to buy tools, this is what I use to make those edges. http://www.eastwood.com/welders/bead-roller.html
OOOOOOOOOOOOHHHHHH!!!!! I want one!!! That's perfect! It does everything I need and a bunch of stuff I don't need but sure can find a good use for!
Old 03-10-2014, 09:21 PM   #120
Dallas , Texas
Just placed my order for buy one get one free on prodex. Getting geared up for Phase 2 of Operation Armadillo.
