Old 01-11-2013, 06:22 AM   #281
65CV's Avatar
Western , Massachusetts
Originally Posted by mutcth View Post
The table fits in the credenza behind the door with the push button release.
Tom
Thanks, Tom.
I looked at some of the other Overlanders on this site and there seems to be a significant leaning towards wrap around dinettes. Easy stowing of the table is a great idea.
John
65CV is offline   Reply With Quote
Old 01-11-2013, 06:48 AM   #282
65CV's Avatar
Hot Water!!!!
The new igniter board arrived yesterday from Precision Temp and took all of 5 minutes to install. Hot water came on right away. What a difference.
It seems like the new heater comes on at a lower flow rate than our 2007 model that we had in the Caravel. The service manual says that it takes 1/2 gallon per minute to get it to light. I thought it was 0.9 before. That's much better for washing dishes and hands.
The problem with the new RV500 was that it had no power to turn on the gas solenoid. Everything else sounded fine up to the expected whoosh when the gas lights. The Fenwal igniter board, the beige board in the back of the electronics drawer had failed. I didn't realize before this week that the electronics drawer slides right out.
I checked into the warranty and -- if I couldn't change the board myself -- the repair would have been very expensive. PT will cover parts and their estimate of the labor cost, but not travel. We were a LONG way from the nearest authorized dealer. I was afraid that I'd have to pull the heater and drive hours to the nearest service, or face a big bill for technician travel.
A multimeter and screwdriver were the only tools necessary. Luckily, the service guy from Precision Temp walked me through the process very patiently. Cost: time and a few days of cold water.
Old 01-11-2013, 07:48 AM   #283
Registered User
Zeppelinium's Avatar
1973 23' Safari
1977 23' Safari
2014 25' Flying Cloud
Palmer Lake , Colorado
Originally Posted by 65CV View Post
... Easy stowing of the table is a great idea...
This table stows in the back of the dinette seat and is just a flat panel, easy to build. Plus, you can have the full sized table and a maskeshift bed, too.
Zep
Old 01-11-2013, 06:40 PM   #284
65CV's Avatar
Zep
Great link, thanks. I missed that thread somehow.
John
Old 01-11-2013, 09:55 PM   #285
reinergirl's Avatar
Hollis , New Hampshire
Here's my thoughts on the whole gaucho vs dinette.... I don't find dinettes to be comfortable, I want a couch to lounge on and if I need to put a table up to play cards or a tray to eat that's fine. I eat for far less time than I would spend say reading a book or watching TV or reading the forums!
I stayed in a Silver Streak at the resto rally in NM and really liked the front lounge.... I am thinking that this combined with the 50s era table would work for us and we'll be able to move the table outside in good weather ...dual use!
Some pictures here.....
'74 Silver Streak
reinergirl is offline   Reply With Quote
Old 01-12-2013, 03:31 AM   #286
Registered User
1973 23' Safari
1977 23' Safari
Originally Posted by reinergirl View Post
Here's my thoughts on the whole gaucho vs dinette.... I don't find dinettes to be comfortable, I want a couch to lounge on ...
If you design your dinette right, you can lounge sideways on the benches, just like a couch. One thing that can make a dinette way more comfortable is to have the option for a short table (for 2). This makes for a easy place to sit, without the table in the way, and still provide a place to eat, put a drink, etc. As a matter of fact, the Overlander has both a long and short table and we have never even put the long one up.
I admit, however, that you're not going to be spooning on a dinette bench.
Zep
Old 01-12-2013, 09:19 AM   #287
65CV's Avatar
Thanks for all the input on designs. We're sitting at our uncomfortable card table and chairs envisioning what would work best. Comfort is number one on the priority list.
Since we tend to go away for 2 straight months in the winter, we want to be sure we can live nearly full time with our final version.
With craft and knitting projects constantly underway, M needs a good table surface. I do a lot on the laptop and also need table space. We also need to decide on the right spot for a TV, which will most likely end up by the fridge.
I've attached a pic of our Caravel dinette. It worked relatively well for us, but the angle of the back cushion needed work and we could have used more storage.
We won't have as much room as Zep has -- our Overlander is a foot shorter and we plan to extend the galley about 2 feet to house an A/C, Toastie style. The extended galley will encroach on a long L-shape lounge, making it a bit more of a design challenge.
All these options make this a good problem to have.
Old 01-12-2013, 09:19 AM   #288
Central , Mississippi
If you design your dinette right, you can lounge sideways on the benches, just like a couch. One thing that can make a dinette way more comfortable is to have the option for a short table (for 2)....
Zep
That's pretty much what we are doing. The table is a single post mount so it rotates. Being 28" x 42", spinning it results in a short/wide or a long/skinny.
The cushions are reconfigurable to make back rests for lounging long-ways on the sides. I actually started to make the seat bottom corners lift up to form back rests but in practicality, we didn't need that feature.
We hope to have the upholstery done next week and give it a shot...
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie(RIP) -
A honkin' long 34' named AlumaTherapy https://www.airforums.com/forums/f20...num-54749.html
and a 26' '63 Overlander, Dolly https://www.airforums.com/forums/f10...ome-71609.html
Old 01-12-2013, 12:58 PM   #289
mutcth's Avatar
2007 23' Safari SE
Central , Connecticut
You should head to IKEA (I assume Austin has one?) and get a pair of Poang chairs for the next few weeks. Cheap, comfy - and they don't take up much space in the landfill if you don't want to bring them back.
One more thing - we also found that it's wonderful to have free floor space against the wall under the front curbside window. Place to stack stuff when loading, makes interior feel more open. Our lounge has a shelf behind it beneath the window (complete with a bin that houses all of J's yarn supplies) and a wide "arm" at the curbside for books/drinks. In other words, you can carve out some horizontal surfaces here and there...
Tom
Now: 2007 Safari SE 23' "Anne" towed by 2011 Dodge Durango "Herman"
Before: Argosy Minuet and T@B, towed by various Honda Odysseys
mutcth is offline   Reply With Quote
Old 01-22-2013, 06:01 AM   #290
65CV's Avatar
Tom
Tom,
I ended up getting a foam cushion for the chair and we're spending more time outside now that the weather is MUCH warmer.
I like your idea about a bin for yarn supplies. M has been spending a bit of time taking the free lessons at Hill Country Weavers. She raves about the place -- another good reason to get J down here.
I agree -- horizontal surfaces are at a premium in our trailers!
John
Old 01-22-2013, 06:06 AM   #291
65CV's Avatar
It's incredible how many vintage trailers have been and continue to be converted into food trailers in Austin. Some good restaurants add to their brick and mortar offerings with trailer food, while others apparently are making the transition from trailer to brick. Two of our favorite spots are the whole South Congress food court (the cupcakes are way too good!) and Spartan Pizza on 6th. Pretty nice trailers too.
No real work is happening on the Overlander. Spending more time on Lady Bird Lake trail, trying to work off the good food. Weather is terrific.
ID:	177174   Click image for larger version
Old 01-22-2013, 05:11 PM   #292
mutcth's Avatar
2007 23' Safari SE
Good food and yarn?!? If we didn't have a trip booked to St. Pete already...
Tom
Old 03-13-2013, 04:39 AM   #293
65CV's Avatar
Sputnik is back in place in the backyard. We managed to break up enough rock-solid snow to get it barely inside the fence, then in place between snowstorms. It should be VERY worth it next week, assuming all goes well with the delivery of our next grandchild.
Work will be on hold for a while, taking care of family and house. In the meantime, we'll try to remember those Florida sunsets. It's days like this that make all the work worth it!
Old 03-13-2013, 01:30 PM   #294
I stayed in a Silver Streak at the resto rally in NM and really liked the front lounge.... I am thinking that this combined with the 50’s era table would work for us and we'll be able to move the table outside in good weather ...dual use!
'74 Silver Streak
I really dislike both the look, and feel, of a gaucho. And for our family of 2 adults and 2 small kiddos, I just don't think it would be practical. As Zep has mentioned, dinettes can be made to be comfortable, and if you drop the table you can turn it into a big bed and lounge all you want, with enough room for the whole family!
I'm beginning the design phase for the front half of my trailer, and I'm pretty well set on creating a modular U-shaped dinette with a table that drops easily into the "pit" to become a (roughly) queen size front bed. The table will be easy to drop and lift (I've seen hydraulic lifts in marine dinettes that would likely work, as well as a few Forums members who have done similar). That will become the main sleeping area for my wife and me, and the kids can move to the midships twins. It'll take a bit of extra time to convert the bed to a dinette during day use and then back into bed form later, but it's no different than the amount of work we're doing currently, switching Superbed from a giant King+ back to twins/couches for day use.
But because I've grown to love the big open front salon area in certain applications (like tailgate parties), I'm also going to make the entire dinette modular and easily removable. I'm imagining some sturdy clamps that flip over lower frame rails on some modular seat/bench-sized pieces, and through-bolts that hold it all in place. That way each piece can be installed and removed coming through the front door, and I can pick and choose which pieces I have in place for any given application. Hopefully more to come next winter!
John-- So very sorry I missed y'all when you were in Austin, work was extremely busy and I had much more travel than usual from December-February. But PLEASE do drop me a line next time you're in town and the Shiner Bock will be my treat! By then, you'll have a finished trailer to show me no doubt, and perhaps I will, in turn!
Take Care!
Old 03-13-2013, 07:01 PM   #295
65CV's Avatar
Originally Posted by utee94 View Post
... Hopefully more to come next winter!
Take Care!
Marcus -
Thanks for putting the offer of a beer in writing -- we'll definitely take you up on it. I look forward to seeing your design. Since I hope to get a head start on the front end of the trailer this summer, I'll be watching your thread for clues on your design.
John
Old 03-15-2013, 01:31 PM   #296
65CV's Avatar
My son's father-in-law is a prolific painter. Based on a picture we took on the shores of the Mississippi in January, he painted this (see post 269 in this thread). He may have taken a few liberties with the time of year -- adding leaves and sailboats.
Old 03-15-2013, 07:13 PM   #297
Thats a cool painting!
Old 03-18-2013, 06:55 AM   #298
Definitely, what a cool painting and nice gesture. I also really like the aluminum-like frame, with its rivet-head detail. Are those bucked, or did someone spend a lot of time with a rivet shaver?
Old 03-19-2013, 05:41 AM   #299
65CV's Avatar
LOL!
Should have stayed in Austin. Rumor has it that Spring is scheduled to start tomorrow -- right!
Old 03-19-2013, 06:40 AM   #300
LOL!
High was 87 at my house yesterday afternoon, wish you were here!
1959, 1959 overlander
1960 Pacer restoration sigv 1960 Pacer 10 07-11-2019 07:00 PM
5th Annual Restoration Rally ! Ken J WBCCI Rallies & Events 195 07-11-2012 11:22 PM
Local Restoration Businesses mncate Interior Restoration Forum 12 04-04-2012 11:13 PM
Electrical supply for 1967 26ft Overlander iAaz Electrical - Systems, Generators, Batteries & Solar 0 03-12-2012 12:56 PM
1967 Airstream 27' Overlander Land Yacht eBay Watch Airstreams on eBay 0 03-11-2012 02:30 PM
