Old
2024 Classic 30 RB - Hitch and AirSafe Question
Posted 05-22-2025 at 12:16 AM by VinitVerma
Originally Posted by StuartsDad View Post
I have used the Blue Ox Sway Pro since purchasing 28' AS in 2018. No issues with hitch. Late last year, added the Air Shocker for WD hitches attempting to soften the ride in the cab and hopefully be alittle kinder to the AS. Jury still out. It does feel alittle smoother on concrete interstates with poorly repaired joints and bridge transitions. Is it day and night difference, no. It is heavy. The Air Shocker with Blue Ox head is 73 lbs. I might suggest starting with your hitch of choice and
Posted in Uncategorized
Views 160 Comments 0 VinitVerma is offline
Old
Posted 05-22-2025 at 12:07 AM by VinitVerma
Originally Posted by Al and Missy View Post
You didn't say what the cargo carrying capacity (payload) on the door sticker is, but you are probably fine.
The unloaded hitch weight isn't very useful; it will go up significantly with water, clothes, accessories and food added. The way I figure it is to use the tongue weight recommendations for stability of 10%-15% of trailer weight so I use the GVWR, which is the heaviest the trailer should ever be. I use 12% - estimated hitch weight is 1200# + 100# for the hitch which
Views 142 Comments 0 VinitVerma is offline
