-   -   Pully that 454 (http://www.airforums.com/forums/f159/pully-that-454-a-97883.html)
choctawmel 10-24-2012 02:06 PM
Pully that 454
5 Attachment(s)
I have started my winter project.
Objective: Pull the 454 cid engine and rebuild it into a 496cid with hydraulic roller cam. While I'm in the area: new 140 amp 1 wire alternator, new A/C compressor, hydraulic pump, high volume oil and water pump, new hoses, and many more to be discovered.
Attachment 171248
First a picture as it was
Attachment 171249
down to the cooler draining
Attachment 171250
looks like I need to add more parts to my parts list
Attachment 171252
what a mess!
Got to stop at this point to recover from eye surgery for 2 weeks.
Mike Leary 10-24-2012 02:16 PM
i would assume the new engine has a better manifold design than the 454. Kudos to you! Keep us informed! :clap:
bkahler 10-24-2012 02:16 PM
Great! I'm definitely going to keep my eyes on this thread!
I really like that scoop under your bumper channeling air to the cooler. Great idea.
Thanks!
perryg114 10-24-2012 02:24 PM
Is the motor already fuel injected? The roller cam is a good idea and is a weak spot on these older push rod V8's. The roller cams are one reason modern engines last so much longer.
Perry
ventport 10-24-2012 04:04 PM
I would NEVER go to a one wire alternator in a motor home. You need the voltage sensing ability of a 3 wire system. A one wire alternator is only good for a tractor with a limited electrical system. Go to this link and read about it before you waste your money on a one wire alternator. Brian
Catalog
choctawmel 10-24-2012 07:39 PM
Already have the 'Banks' system on it. The intake may get changed if it's not aluminum. Do plan to re-use the TBI I have on it.
choctawmel 10-24-2012 07:45 PM
Thanks!
Looks like the oil cooler is going to be in the way and the scope may get a redo. I have another (trany) cooler behind the right headlight.
after I took the radiator off, I power washed it, the A/C condenser, and the main trany cooler. With all the trash I washed out of the fins no wonder it runs hot.
choctawmel 10-24-2012 08:01 PM
Catalog
Interesting! Never thought about down steam voltage. May be why the warning lights 'low coolant' and 'water in fuel' are on at times now for no reason.
Well re-think that and complete reading the link at a later date.
I need to go put an ice pack on my forehead now. I hate getting cut on!
jm2 10-24-2012 08:35 PM
what do you like for a cleaning agent on coiled & finned radiators & coolers, etc.?
PeterH-Airstreamer 10-25-2012 05:36 AM
My Hi-tech bug collection system for the big trips :D You would be amazed to see what all you catch...
choctawmel 10-25-2012 08:31 AM
Perry
Yep, the motor has been fuel injected since I installed it in 2004. One of the best upgrades I've done. Got 30% better mpg and lot more power. With a hydraulic roller cam the duration of the valves can be longer making for better breather, valve open/close faster and a lots less friction.
choctawmel 10-25-2012 08:43 AM
I just used one of those cheat electric power washer. I've tried a cleaner from my local A/C supply store, but wasn't impressed with it on my house A/C units and guess it didn't work very well on the Silver Bullet's radiator either.
bkahler 10-25-2012 11:45 AM
I doubt I would be surprised at all :)
I drove from Dallas to Little Rock every weekend for 3-1/2 years and the front of my car pretty much stayed bug covered that entire time :sick:.
choctawmel 10-25-2012 02:25 PM
Being my face hurts and I'm not to do anything for the next week I've been shopping for a radiator.
Many one know the GM part number? With the part number I hope to cross it to a aluminum radiator....
