-   -   '74 Argosy mh P30 radiator isolation mounts (http://www.airforums.com/forums/f159/74-argosy-mh-p30-radiator-isolation-mounts-97616.html)
bkahler 10-17-2012 10:38 AM
I'm in need of the rubber isolation donuts that are used on the mid 70s to early 80s P30 motorhomes to mount the radiator to the frame. Looking at the attached picture you can see the donuts that I need. I've tried googling without any luck. I tried RockAuto and they don't seem to carry them either.
Attachment 170527
I could probably make some out of soft nylon or similar but would prefer to get the right piece.
Any suggestions?
Thanks!
dadstoy 10-17-2012 10:44 AM
Sorry Brad, but you can't have mine! :)
dadstoy 10-17-2012 10:51 AM
I bet you could find something at LMCTruck.com that would work just fine.
http://www.lmctruck.com/icatalog/cc/full.aspx?Page=37
bkahler 10-17-2012 11:04 AM
If I remember right you're out playing on your ATV and I'm only about 450 miles from you right now so keep that in mind... :brows: :D
bkahler 10-17-2012 11:11 AM
Truck Parts and Truck Accessories
That looks promising. It will probably be worth ordering a set to see if the dimensions will work.
Ok, so now I need to remember to search LMC Trucks for parts as well :)
Thanks!
