-   -   '86 Sovereign Lower Window Latch won't lock (http://www.airforums.com/forums/f164/86-sovereign-lower-window-latch-wont-lock-97528.html)
ASRally 10-14-2012 04:44 PM
Window latch handle is jammed in the open position and will not move to lock the window when the latch arm in the locking position.
Can this be removed and repaired with lubricant or will it need to be replaced?
gmcryan 10-14-2012 08:52 PM
All I can say is, don't force it down. I broke one of them a few days ago. That little part is somewhat expensive relative to its size!
Inland RV Center, In 10-14-2012 08:58 PM
Remove it and soak it in WD-40 for a day or 2.
It's problem is that the shaft is corroded.
ASRally 10-17-2012 06:04 PM
Thanks for the info gmcryan and Andy.
I'll remove it and soak it in WD-40 a day or 2 as suggested.
