-   -   Pesky window screw (http://www.airforums.com/forums/f164/pesky-window-screw-97240.html)
dclampe 10-06-2012 06:31 AM
Pesky window screw
I'm replacing windows in my 65 overlander and there's a screw in the top channel right under the gutter that needs to be backed out before the window can slide out. The first one I did I bent the gutter up and got the screw out and was able to bend the gutter back into place without too much trouble, but I'm searching for a better way. I'm guessing the only other way would be to remove the gutter? What have others done?
Also, the screw appears to be steel. Does anyone have a source for a stainless replacement?
RickDavis 10-06-2012 07:02 AM
Needle nosed vise grips clamped on the screw head may work.
Sometimes a really short screwdriver bit like used in drills can be used as a right angle screwdriver by putting a 1/4 inch box wrench on it
Sources of stainless screws can be found on the net but I don't have the info handy right now
StPierre 10-06-2012 07:31 AM
I just finished all the windows in my 65 Safari , and I had to bend the gutter up and used neddle nosed vice grips as Rick stated. I found that was the best way
Silver Goose 10-06-2012 08:00 AM
Originally Posted by dclampe
... Does anyone have a source for a stainless replacement?
Have you checked with Lowe's or Home Depot? They have a fastener aisle that has a variety of screws and bolts packed in small quantities, I've seen some stainless choices the last time I was looking. Also check the yellow pages under fasteners to see if there is a retail distributor nearby. They usually sell by the box.
airstream4 10-06-2012 08:18 AM
I have used vise grips with some success and a grinder and drill another time. I use McMaster Carr for stainless screws. I was afraid of bending the gutter, thought i might destroy!
Good Luck
Paul
dclampe 10-06-2012 06:55 PM
Thanks for the suggestions. I'll give it a shot the next few days. :bb:
awolff 12-02-2012 12:56 PM
If you have an Ace Hardware or True Value, they usually have stainless screws.
