-   Tires (http://www.airforums.com/forums/f438/)
-   -   Tire pressure monitor recommendation? (http://www.airforums.com/forums/f438/tire-pressure-monitor-recommendation-96429.html)
jhfarrar 09-14-2012 04:13 PM
I have a 2012 27ft Flying Cloud (4263) towed with a Toyota Sequoia SUV.
I have been advised that a tire monitoring sensor is critical for safety and need a recommendation. Apparently some need signal boosters and some do not.
If there is a good one without the booster and a monitor that is battery operated that would be my first choice.
I have looked at the Tire-Safeguard 6 tire TPMS for $329 and it sounds ok but they mention it may need a booster.
Please give me your ideas
jfarrar@cox.net
Distantdrummer 09-14-2012 04:18 PM
I too am seeking info on various monitors.
I am wondering if any of them have an audible alarm at the read-out device for pressure drops and/or sending failures.
Also do all of the sensors require the tire to be dismounted? In other words do they REPLACE the existing stems?
Ridgerunner3 09-14-2012 04:34 PM
I bought the Dill system from Tire Rack. I does it's job but the display is difficult when the sun is shinning on it. So I leave the display down on the transmission hump. As long as you keep it out of full sun you can read the display. I called Dill about the sun shine effect on the display, they said that have another display that works better in full sun.
The display steps through the tires one at a time. You can also read air temperature inside the tires. I can't remember if the temperature alarms. The monitors are mounted inside the tire similar to a truck TPMS system. It alarms for high and low pressure. You set it up for the normal running pressure of your tires. It has a magnetic remote antenna that I have mounted to the back of my truck frame.
I have no experience with any other TPMS systems other than those mounted from the factory on automobiles. So I can't compare it with other TPMS systems.
AWCHIEF 09-14-2012 04:34 PM
Some require the replacement of the the stem and some you only replace the cap with the sender. You will have to check with each brand. GOOGLE is a good place to start.
pappy19 09-14-2012 04:37 PM
I've been using the Hawkshead Pressure Track HD which has 5 year battery life in the tire monitor stem itself. It has saved my donkey twice. No your tire doesn't need to be remounted. The stem monitor just screws on the tire stem itself. The digital monitor needs recharging every 2-3 days. Once you get your tires programed, it's a snap. I did have to call the company tech to get mine set up. Their directions left me but the tech walked me through it in 10 minutes. Here's their link.
HawksHead Pressure Track HD
twobikes 09-14-2012 04:47 PM
We are also having good success with the Hawkshead and I agree the customer service is first class. They recommend that you use steel tire valves (for obvious reasons). I had trouuble receiving the signals when I mounted the monitor in the center of the windshield, so i bought the repeater and mounted it in the front window of the AS. no problems after that. Another forum member with a longer rig suggested I just move the monitor to the corner of the windshield as that had worked for him.
purman 09-14-2012 05:21 PM
I have been using "Tire Minder" The sensors screw right onto the valve stem and give you pressure and temp. You can set the pressure warning alarm to what ever pressure you want. They give you extra batteries and will give you new ones if you send them your old ones. It needs no boosting and I have driven a good 25 feet from my trailer and still had them working. (28' AS ) The monitor is small and fits on the windshield with the attachment.
It has rechargeable battery built in and last a few days without charging. It is also expandable to 22 tires. You can put them on your TV or another trailer. You can't put them on the Sequoia though, as it has built in TPS system, and they say it won't work with them. I haven't tried it on my Sequoia to see if its true. I used the system on my last 3000+ mile trip. Loved it. Personally I think putting LT tires on you AS is also a good why to not have to worry about your tires. I just did that after my last trip with 16" rims..
Foot note: Hawkshead and Tire Minder are the same thing with different names. At least thats what it looks like since they look exactly the same.
Ebay has them for $258
http://www.ebay.com/itm/TireMinder-T...r#ht_827wt_907
nilesrob 09-14-2012 06:26 PM
Have the Hawks Head - no repeater needed, although I ordered it thinking I would need it. Has temp and pressure, sounds off when exceeds limits. Good so far - happy to say I haven't needed it! One of the other benefits is you no longer need to check your individual tire pressures, since they all report back.
ZoominC6 09-15-2012 06:59 AM
We've been using Pressure Pros for years (6+) and they have saved us once already. They utilize both audio and visual alarms at various stages of pressure loss. Coupled with Centramatic wheel balancers we feel very confident that our rolling gear is doing well and not about to destroy our aluminum skin or dump valves while rolling. Maintaining no more than 65mph with 65psi air pressure also seems to help preserve the rubber.
GCinSC2 09-15-2012 08:53 AM
I have the Dill. Internal sensors monitoring PSI and temp. The display has a stem antenna and mine came with a remote magnetic base cable antenna. I use the mag base, no repeater. Tire must be removed to install sensor. Tech MUST be trained on mounting procedure for internal sensors which just about all new cars have now.
A TPMS is a good idea.
ThreeFingers 09-15-2012 08:57 AM
I have the "Tire Minder" and it works great. We have driven from California to North Carolina four times with this unit, I used velcro to attach it to the dash of our truck, keeps it out of the sun. Drove back to Calif. last June, 3,000 miles I40 no problems until we got off the hwy 99 to go to our home, by the time I drove the 4 miles to our house the alarm went off on our left rear tire, we picked up a nail in the side wall. The unit worked just like it should have, told me we had a loss of air pressure and what tire it was. It is also nice to be able to see the tire temps when driving I40 in the heat of the day.
JMSx2 09-15-2012 09:21 AM
I also have the Tireminder on my Land Yacht. I bought it primarily for monitoring the air pressure in the tires but on a recent trip the right front tire had an alarm on heat and when I took in the shop for some minor work they found a broken part in the right front brake. Glad we purchased the product.
mstephens 09-15-2012 09:32 AM
I recently installed the Dill TPMS when I had new tires mounted. My tire outfit was completely familiar with Dill installation.
My Experience
The short stubby antenna did not pick up a steady signal. So, I installed the rooftop antenna with the magnetic base. I placed it all the way back on my Suburban rooftop. The signal was then perfect and reliable.
The display works by displaying one tire at a time. It rotates around the four tires stopping at each one for about 3 seconds. If at any time you want the tire temperature instead of pressure, you depress a button on the corner and the display will momentarily read temp and then go back to pressure.
The display unit is very small - much smaller than you expect based on pictures you see. It is about 3" x 2" and 3/8" thick. The numerals are LCD and if too much sun is on the display you can't read it. The display comes with an excellent and very robust ball mount with suction device - a lot like the GPS units use. It works very well, HOWEVER....
What I do not like is the very awkward arrangement of the display unit connectors. The antenna comes straight out the back, and the power comes straight down off the bottom edge. In other words, the two cords are at 90 degrees to each other, which makes it nearly impossible to mount this in a "slick" way. Using the supplied ball mount, this little display takes over the cockpit. A bit ridiculous.
I got some right angle connectors, fabricated a little bracket, and was able then to mount it in a little spot with my CB radio. Very tidy, and very readable from the driver seat.
The unit is powered by cig lighter cord, and includes an optional cord with raw wires on the end if you want to wire it into the existing circuits. If your cig lighters are live with key out, like mine, you will have to plug and unplug.
Is it accurate? I measured with my digital pressure gauge and the readings were +/- 1/2 pound. Not bad. I think it is VERY useful. It will highlight a tire problem pretty quickly for the driver. It is set to flash an alarm at 20% high or low from the desired set pressure. In my case, the set pressure is 50#.
I paid $239 and it was installed with my tires for no charge.
If I could make a change, I would show all four tire pressures at once, and I would change the connectors to all exist in the same direction.
jhfarrar 09-15-2012 12:16 PM
16" LT sounds good, AS rims?
What did you do for rims; AS or Tire Rack?
TireMinder Tire Minder pressure Monitoring System RV 5th Wheel Motorhome | eBay
