-   Audio, Video & TV (http://www.airforums.com/forums/f450/)
-   -   2011 Eddie Bauer - Sony DVD Player (MIC IN cable) (http://www.airforums.com/forums/f450/2011-eddie-bauer-sony-dvd-player-mic-in-cable-93394.html)
Missy Grace 07-06-2012 05:19 PM
Hopefully an audio person can answer this question. My unit has a cable in the overhead bin that feeds into the side wall to the Sony DVD player (my assumption). The cable is labled MIC IN. If I set the Sony mode to AUX FRONT-IN, I can play songs from my MP3 player by plugging an AUX cable into the AUX connector on the front of the player. If I set the Sony mode to AUX REAR-IN and connect to the MIC IN, nothing is played? Is the AUX REAR-IN connected to this MIC IN cable? Any help is appreciated.
Missy Grace
Westfalia 08-23-2012 02:43 PM
The MIC-IN cable is for a karakoe mode on your receiver. Do you not to have two barrel connector labeled AUX IN inside the cabinet on the same wall as the MIC-IN jack?
drew05 08-23-2012 03:47 PM
The "Rear In" connection is the audio feed from the TV. If you have a factory installed DVD, this might be the setting you are looking for.
I'm not sure how yours is wired, but I would think that the DVD would be wired directly to the radio. If you are adding a DVD I think I saw some unused connectors that were taped up.
There is a submenu selection for the mic in. I don't remember where it is. The Sony owners manual is very good as it covers everything. There might also be an installation sheet(s) that show how to wire additional components. I'm at work, but I'll look when I get home.
Have you tried connecting the DVD to the Aux connection?
Good Luck :)
Gringo 10-02-2012 01:05 PM
I was about to post this same question when I did a "Search" and found this thread.
We have the same question. 2011 27FB. Inside the overhead console is a pigtail with a mini jack connector, labeled "mic in". we haven't been able to figure out what to do with this. We wanted to play the ipod through it. But no matter what combination of settings we used, nothing comes through the speakers with the ipod plugged into the "mic in" jack.
Works fine when we plug it into the connector on the front of the Sony.
So, whats the "mic in" connector supposed to do? Seems someone went to a lot of trouble for something. Must have a use of some kind?
Antique Pedaler 10-02-2012 01:35 PM
If I remember correctly, there are aux 1 and aux 2 settings. I plug the ipod into the mic jack and turn to aux 2 for it to work. Then I plug the ipod power cord into the 12 v receptical next to mic in. Then all cords are inside the cupboard.
