-   -   Refinishing Window Frames (http://www.airforums.com/forums/f164/refinishing-window-frames-93110.html)
StPierre 06-29-2012 09:12 PM
We reinstalled the belly pan, set up and tested all the plumbing, electrical and gas lines and now on to the windows.
The window frames are pitted. Are there any suggestions or techniques to bring back the aluminum finish? I have added a picture of the window frame and the reinstalled belly pan. One step at a time!
Eric H 06-29-2012 09:14 PM
Wire brush on a drill should get most of the corrosion off. You can sand them by hand after to make them really smooth again.
cuyeda 08-14-2012 05:05 PM
I will defer to the experts, but depends on what outcome you want. For starters try a 00 fine steel wool and WD-40. That should bring it back to a matt aluminum finish. The corrosion pits may still be left behind, but at least it will be cleaner. For further results, others may chime in! I try to stay away from sand paper, but that is just me.
StPierre 08-15-2012 09:19 PM
I have finished all but one window . Started with a wirewheel then used 200 grit then 400 grit finished with 1500. with good results. a fair amount of work , but worth it . I will post a picuture when all windows with new screens installed
StPierre 08-30-2012 07:44 PM
We did it! We finished rebuilding all the windows. New seals and gaskets and screens on the Safari.
rumrunner 08-30-2012 09:31 PM
Beautiful! You give me hope that mine will look as good someday.
tim
flyfishrra 09-12-2012 04:53 PM
So where does one get the new belly pan material? And if I wanted to insulate the underside better what would I use? Not a fan of the fiberglass insulation. Foam board insulation maybe? Lots of my pan has extra holes or is rotting out. want to maybe get started on replacing it soon.
StPierre 09-17-2012 11:15 AM
Flyfishrra Iam not sure were to get a belly pan . I used 1 inch foam board glued and screwed to floor. I also used foil tape on all seams
KCN 09-17-2012 12:20 PM
Windows/Screens look amazing; starting mine now - thanks for posting the how-to!!
Kathy
inTransit 09-17-2012 12:24 PM
I got bellypan sheet aluminum 48" wide cut to length and shipped from airparts. Cant remember the type and grade but its in the forum history if you search. Some say local materials shops may carry also but after several phone calls and lots of indifference/indecision (we might have it/larger order, etc) by them airparts was far more convenient and price competitive.
awolff 12-02-2012 12:49 PM
Hi Flyfishrra, we got .025 4x8 aluminum sheets from a local outfit that sells alumimun.
We also used the foam board and glue like St. Pierre instead of the fiberglass pink stuff. We used the belly pan rivets from Vintage Trailer supply. It was a painstaking project, we replaced all the underbelly panels.
Jonn Five 05-29-2013 03:29 PM
Looks Great! Just picked up a 1954.. Cant wait to get to this point... Any tips on where I can start looking for seals and gasket for the window frames and door?
