-   -   locked out of AS Help (http://www.airforums.com/forums/f164/locked-out-of-as-help-91632.html)
outandabout 05-25-2012 02:27 PM
I'm camping in my '68 GT AS and closed the door. The knob turns on its' axis and does not engage the bolt. Short of cutting the knob off, how can I open the door? Kevin
Naper 05-25-2012 02:37 PM
Take a look at the hinges. Can you drive the pin out.
dznf0g 05-25-2012 02:48 PM
Call Andy at Inland. I don't have the number....google it....he seems to know how to get into all of them.
dznf0g 05-25-2012 02:49 PM
800-877-7311 is his phone number.
Melody Ranch 05-25-2012 03:23 PM
Try pushing in on the nob, hard, as you turn it. I had a similar problem in my 66 and that got the door open. Then fix/change the lock.
RickDavis 05-25-2012 03:37 PM
I have had some luck entering through one of the cargo hatches, depending on size and location. In my case I was able to push the bed out from the underside and get in. Of course I was smaller then also
goransons 05-25-2012 04:27 PM
Be careful with that L-100 lock, discontinued and getting harder and harder to find. If you have some access doors and personally can't get in, find a good elementary kid that can use a screw driver, get him/her inside and have them remove the screws to take the inside handle off.
rverruni 06-04-2012 09:18 PM
I am a new owner of a 71 Overlander and got no keys for baggabe compartments. Can the cylinders be changed?
Rich
