-   -   Tranny Shift (http://www.airforums.com/forums/f159/tranny-shift-9042.html)
smily 01-27-2004 07:24 AM
Tranny Shift
My 1990 33 LY seems to be shifting incorrectly.
It was shifting okay until the other day when I took it to town to have it compounded and waxed.
I have been underneath the doghouse working on belts. Maybe I loosened something up inadvertantly.
It seems that the engine is revving up way to high before the transmission shifts to the next gear.
Is it possible that I have a vacuum leak somewhere?
What tells the transmission to shift in a timely manner?
I am assuming that the Tranny shifts when a ceratin level of vacuum is reached by the intake.
Please advise,
Smily
74Argosy24MH 01-27-2004 07:40 AM
What tranny? Some are electronic, some vacuum/governor.
thenewkid64 01-27-2004 07:41 AM
Ken,
Depending on the exact model there is a vacuum line that runs from the intake manifold to a valve on the side of the transmission. If the line is cracked or has come off you will have wonky shifting. I would start there. I have replaced most of my vacuum lines, but I have fewer lines than you do.
smily 01-27-2004 07:45 AM
Tranny type
Umm, only description I can give at this time is, Chevrolet, no overdrive, 454 engine and 1990 model.
All I know from here. I can ook at book later.
Smily
87MH 01-27-2004 07:47 AM
Each year unique?
The only outside signal going to my tranny is (I think) an electric signal originating from a full throttle situation which precipitates a downshift. The Xeppelin has a fairly harsh shift it it shifts under a load.
thenewkid64 01-27-2004 08:03 AM
I know Fred (1985AIR345) had the same type of symptom. He had a bad vacuum line and he had the same type of problem.
