-   -   side window busted, need to replace-advice? (http://www.airforums.com/forums/f164/side-window-busted-need-to-replace-advice-89834.html)
deelind 04-11-2012 04:19 PM
Hey Folks, Lawn guy busted my side window (29") on my Safari and looking to replace it. Called for a new one, yikes $469- if I can't find a more reasonable priced window, I'm wondering if I can't use plexi in there until I get one, any suggestions? Thx ~D
AIR-Quarius 04-11-2012 04:35 PM
a WEED EATER got our side window and it was a 400.00 fix- we ordered it from inland (Andy and the gang)....yeah, if you can get a piece of plexiglas that has enough flexibility in it, you would want to cover it for until you get a new replacement. Another covering is contact paper like you get at Walmart (about five dollars for a jumbo roll of white). Just lay out sizes larger than the window frame and while the wind is not blowing spread enough paper over it and trim off the excess. Hope you get your new window replaced soon.
overlander64 04-11-2012 04:44 PM
Greetings deelind!
You might find that Lexan is a better substitute than Plexiglass. Over ten years ago, I got tired of replacing the flat glass front window on my Overlander, and switched to Lexan. That Lexan window has withstood more than ten seasons on the road without the protection of a rock guard (I like to make use of the "see-through" feature on the coach so have never installed a rock guard on this coach). Unlike an earlier attempt with Plexiglass, the Lexan has stood the test of time without the hazing, scratches, and discoloration that I experienced with Plexiglass. Whether Lexan or Plexiglass is utilized, I have found that the seal between the window and frame will require annual attention to keep the seal between the frame and acrylic material waterproof.
Good luck with your project!
Kevin
P.S.: You might want to consider checking with your insurance agent to see if your homeowners' insurance might assist with the cost of replacement if you decide to pursue a new glass window replacement for your coach.
montanablue 04-11-2012 06:11 PM
Call me I have some of those windows. Contact me at r_whiten@hotmail.com
Rick
Inland RV Center, In 04-11-2012 06:55 PM
Suggestion.
That's why your supposed to have insurance.
azflycaster 04-11-2012 07:05 PM
Shouldn't your lawn service be picking up the tab?
deelind 04-11-2012 08:49 PM
Hey AIR-Quarius, Thanks for the advice, Lexan is a great suggestion. Checked out yr site, great artwork, I'm a muralist as well (Decorative Painting Portfolio).
Andy, I can't get insurance until it's registered and that will happen when it becomes road worthy (which could be a while). Also, even with homeowners or any other type isn't there always a deductible ?
Aage 04-11-2012 09:15 PM
You got that straight. Up here, a popular deductible is $500, and if you make a claim, you will almost always pay the insurance company back for it in the next year or two's rate hikes.
What's the point of having it, you ask? I am really wondering that myself.
AIR-Quarius 04-11-2012 09:45 PM
Lean in Montanablues direction. It's great when you can keep everything stock on the Airstream. You have some very very nice art works too!
Protagonist 04-12-2012 05:16 AM
In engineering terms, both Lexan and Plexiglas have a different coefficient of expansion than does glass. Cut the Lexan just slightly smaller than the glass it's replacing, to give it more room to expand in the heat. That will help prevent it from "crazing". The difference in size needn't be (and can't be) much; after all, it still has to fit in the original weatherstripping. Hence the need for constant attention to keep it waterproof.
By the way, Lexan the same type of polycarbonate material used in safety eyeglasses; you can hit it with a rock and do little damage, but you can scratch it by trying to clean it with a dry paper towel. clean it carefully!
overlander63 04-12-2012 05:31 AM
The people that keep glibly advising others to get their insurance to pay for the damage don't seem to have heard the phrase "actual cash value". Our state requires insurance on travel trailers, and "actual cash value" on our '74 is $500. So, if you turn in a claim for a $400 window on a $500 trailer, you could well end up with no trailer at all, and a check for $500...
overlander64 04-12-2012 10:01 AM
I have had both automobiles and travel trailers with acrylic windows starting with a 1968 Mustang convertible that had a hinged acrylic rear window, and then in 1980 a Nomad 1780 Light Weigh Special Travel Trailer with all acrylic windows. I discovered just prior to purchaing my Minuet in 2003 that it too came from the factory with acrylic side windows. While the acrylic windows require specialized care, they can have a longer than expected lifetime. Aircraft Spruce offers a wide array of products to care for acrylic windows and I have relied upon their products since purchasing my Minuet in 2003. These cleaners/conditioners/polishes also work well in maintaining the appearance of the three-piece Airstream rock guards as well.
Kevin
AWCHIEF 04-12-2012 10:14 AM
The PO of my Bambi II replaced 2 of the windows with acrylic of some sort. The only time I ever notice that they are not glass is when I touch them. They are leak free and fit solid. I might get around to replacing them with glass one of these days, but right now that is pretty low priorty.
deelind 04-12-2012 10:50 PM
Great advice from everyone, always impressed with how helpful this community is, think it's the best thing about owning a unit. Thanks so much.
also
"Shouldn't your lawn service be picking up the tab?"
Richard
I can only assume they did it, didn't see it. Did speak with the owner of the company and asked them to be very careful near the unit. Its got me thinking about rock guards....
