-   -   Fresh water tank barbed plastic fittings (http://www.airforums.com/forums/f443/fresh-water-tank-barbed-plastic-fittings-87757.html)
Mrad7777 02-19-2012 05:39 AM
I am plumbing the fresh water tank and need the barbed plastic fittings
That insert into the tank . Anyone know a source for these ?
wasagachris 02-19-2012 05:50 AM
Those fittings are standard RV fittings and any RV shop should have them.
You should post this thread in the plumbing section so other people can find it easier later. This section is for question about using the site.
maybe a mod can move this thread.
68 TWind 02-19-2012 05:58 AM
If you are speaking of fittings that are barbed on one end and threaded at the other, ACE Hardware should have them. I found that the plumbing department in my local ACE had a better selection of plastic fittings than did the local HD.
perryg114 02-21-2012 12:47 PM
Try Mcmaster.com they have everything you need.
Perry
