-   -   1968 Tradewind...New Window Gaskets (http://www.airforums.com/forums/f164/1968-tradewind-new-window-gaskets-87044.html)
gsm1908 01-29-2012 09:10 AM
Hey guys.
I believe it is time to replace the window gaskets on my '68 Tradewind. I am having to clean water from the forward side window sills after heavy rains. I would like to address this problem ASAP.
Any opinions on the best replacement gasket for the 1968 model. Also, what is the best method for doing this job. Any help is much appreciated.
Thank you.
tkasten 01-29-2012 10:33 AM
Try Vintage Trailer Supply or Inland RV.
gsm1908 01-29-2012 10:38 AM
Thank you for the response and I will check out their websites.
Has anyone recently done a window gasket replacement...How did it go... Any helpful hints you can share?
Look forward to hearing from you guys and thanks for the help.
Inland RV Center, In 01-29-2012 10:52 AM
The original flared gasket has done it's time.
A few years ago, we researched Airstream's "D" shaped gasket.
It proved far superior to the original gasket.
So far, thousands of owners have switched to the "D" type.
bbrowdy 06-04-2012 02:27 PM
68 tradewind window gaskets
Hi GSM206, did you rerplace your gaskets and what did you use? any comments?
