-   Doors & Locks (http://www.airforums.com/forums/f453/)
-   -   Key for Water Fill (http://www.airforums.com/forums/f453/key-for-water-fill-85445.html)
VeggieBullet 12-06-2011 10:45 AM
Key for Water Fill
Hi everybody.
Looking at the Key's Chart we see that out
1972 AS as the following locks
Access Door 1101X
Battery Box 1101X
Water Fill G248
Looking @
Keys : Out-of-Doors Mart!, More Airstream Parts on-line than anyone!
We see that they are showing 2 options for WaterFill Keys for AS from 70s to mid 80s.
Any idea witch one should be the one to choose?
DKB_SATX 12-06-2011 10:49 AM
I bought the one ODM calls WF-01 and it worked for my '75 Argosy's Thetford water-fill door.
VeggieBullet 12-06-2011 10:57 AM
Hi DKB
Thanks for the fast response.
By looking at their website and the pictures of the water fill lock it looks the same.
and since we need keys anyways this may work. just don't want to wait few day and then figure it out that we order the wrong keys!
We are also assuming that the access keys were are only one kind since they have only one for sale?
Regards
DKB_SATX 12-06-2011 11:01 AM
Airstream tends to use the same key for all trailers on the lockers, battery doors and water fill. So in general every airstream in year X had the same locker key, etc. Of course, when they changed they continued to use up old stock before starting on the new one, so there's some vagueness in the year a particular key started and stopped, which is reflected in a PDF of key codes by year that Airstream used to host on their service site. They've shuffled pages around and I no longer have a good link to that PDF.
VeggieBullet 12-06-2011 11:09 AM
keys PDF file
this one?
TG Twinkie 12-06-2011 11:24 AM
My '74 Argosy has 5 doors counting the entry door. It takes 4 different keys to open all of the doors. Key #87 = water door; Key #244 = refer and curb side storage doors; The key for the entry door is #733, but it is a new lock cylinder. The battery door takes another key which is not numbered. The blank # of this key is L1054B by ilco.
DKB_SATX 12-06-2011 11:40 AM
@VeggieBullet: That's the one! I've now saved a copy in my Airstream folder on the NAS, thank you.
VeggieBullet 12-12-2011 09:16 AM
Wrong KEY!!
4 Attachment(s)
mmmm:mad:
judt got the keys on the mail.
The Access Door work fine but the Water Fill doesn't even fit.
This is what we got
Water Fill Key WF-01 - $6.95 : Out-of-Doors Mart!, More Airstream Parts on-line than anyone!
Now What?
overlander64 12-12-2011 11:11 AM
Key for Water Fill
Greetings VeggieBullet!
Originally Posted by VeggieBullet (Post 1082204)
mmmm:mad:
This is what we got
Now What?
That key appears quite similar to the one the worked in the original water fill on my Minuet. You may find the same thing that I did . . . the old lock has seized and either needs liberal treatment with PB Blaster to free it . . . or it may require drilling out the lock cylinder and replacing the cylinder with a new unit. Once I was able to access the water fill on my Minuet, I learned that the internal portion of the fill (made of plastic/ABS/fiberglasss or similar) had deteriorated to the point that it leaked profusely and was not repairable. In the end, I ended up having my Airstream dealer replace the entire unit with a new plastic fill device . . . not as elegant as the original, but at least it doesn't leak.
Good luck with your investigation and research!
Kevin
TG Twinkie 12-13-2011 12:33 PM
Has anyone tried contacting Thetford to see if they might have keys?
1972 streamn 06-30-2018 10:06 AM
Yes, Thetford does not have these keys available. (Information current as of 2017)
1972 streamn 06-30-2018 10:08 AM
Need 1972 water fill key, as well.
I am in search of a copy of the Thetford greasy water fill key. 1972 landyacht-globetrotter. If anyone is willing to send me a copy of theirs, I'd be so thankful.
Chase 08-04-2018 02:54 PM
Key code 166
I'm in need of a key for the compartments of a 64 globe trotter I just bought. Looks like the keys used on 64 models were 166. anyone know where I can get one or copy theirs and send me one? It has been sitting for 10 yrs. More questions to come!
