-   -   Plastic window pull guides (http://www.airforums.com/forums/f164/plastic-window-pull-guides-84249.html)
Chuck Neir 10-30-2011 04:00 PM
I need to replace the white plastic window pull guides (that attach to the side of the window frames to hold the windows open. I have the replacement guides (in black). Question: What is the proper size rivet to install the new plastic guides? I assume the rivet is 1/8", but what is the proper length?
Flynavy 10-30-2011 06:48 PM
1/8" dia. with 1" grip. Put in the top and bottom rivets first and drill the middle holes if they don't line up.
Inland RV Center, In 10-30-2011 10:07 PM
#45 or #48 pop rivets will work fine.
#45 has a grip range of 5/16" and #48 has a grip range of 1/2 inch.
I don't know where you would find a 1/8 inch pop rivet with a 1 inch grip range.
overlander63 10-31-2011 05:11 AM
#46 rivets are more than enough, which is about 1/8"x3/8".
Flynavy 11-01-2011 08:23 PM
Opps!!! You guys are right. Having a CRS attack again.
