-   -   Missing screws? on window knobs (http://www.airforums.com/forums/f164/missing-screws-on-window-knobs-83627.html)
screamstream 10-13-2011 04:09 PM
I have a new 2012 AS and I was wondering why all my window knobs seem loose. I think there is supposed to be a small screw in the bottom of knob to help hold it onto rod. (?)
I called Airstream and they thought they were not using screws anymore, but never called me back to verify. (how are knobs supposed to hold on without these little screws?)
My dealer said they would order them, but that was over a month ago, and I am still waiting.
Anyone else with a newer AS have this problem? maybe I am the only one missing all my screws! I can pull the knobs right off and am afraid to loose one.
overlander63 10-13-2011 04:33 PM
The newer knobs are friction fit plastic, with no screws. If yours do get loose, they are pretty inexpensive to replace.
screamstream 10-13-2011 04:41 PM
Thanks for info, BUT I have do have holes in the knobs, seemingly where the screws go. The AS is only a few months old...I surely should not have to replace knobs already...darn, wonder if screws would fit to help my wiggly knobs. I love to have windows open!
overlander63 10-13-2011 04:57 PM
The new knobs have no screws. They are friction-fit only. Trust me on this.
DoubleNickel 09-05-2013 11:18 PM
It's a really poor design. You can get set screws that fit the threaded insert, but when you tighten them up it just drives the insert out of the plastic knob.
Until AS gets tired of hearing complaints about window knobs falling off new trailers and does something about it, a dab of clear silicone will secure them.
SteveSueMac 09-06-2013 05:35 AM
Screamstream - same for us. 2012 Flying Cloud. Window "knobs" have screw holes (brass taps?) in them but no screws. Maybe they SHOULD be tension fit but that's not what they used in our trailer. I'm thinking of bringing one to Home Depot and getting a bunch of screws.
daveswenson 09-06-2013 10:57 AM
Mine are the same way. I was at the dealer yesterday and asked about them. The parts guy knew exactly what I was talking about and had a stash of the set screws. He said there's no part number for them and that sometimes airstream would send them with the knobs, sometimes not. I'll install them when I find my teeny tiny allen wrench.
m.hony 09-06-2013 12:17 PM
I have mentioned this on 2 other threads. Mine are the same way. I even mentioned it to Dave Schuman in Jackson Center.
I am of the understanding that older trailers had the set screws.
Do they really save much money on manufacturing by leaving them out?
Zia 09-06-2013 12:32 PM
Have the same problem with mine, the dealer gave me a few set screws which I used on the windows used more frequently. The press fit knobs get loose with use particularly on large windows where you have to use extra force.
MrUKToad 09-06-2013 12:59 PM
I was a bit perplexed with one. We don't have the set screws but neither do we have any problems with knobs falling off. Clearly we don't open the windows enough!
dkrug 09-06-2013 03:00 PM
We have the same problem. When I called Jackson Center I was told they don't use them any more. I told them the knobs keep coming off and I was told to glue them on.
We didn't glue them on. I just say bad things when one comes off while trying to open a window.
Protagonist 09-06-2013 04:18 PM
Might be able to use Loctite thread locker, for a less-permanent solution. Threadlockers from Loctite Products | Threadlocking / Mechanical Gasketing | Loctite Adhesives
AldeanFan 09-06-2013 05:26 PM
I m sure glad I bought my 36 year old Safari instead of a new trailer, nothing has fallen of the Safari, and I would be beyond angry if I had spent 10 times the money on a new trailer and had parts falling off!
AldeanFan 09-06-2013 05:27 PM
They really said that!
new trailers should not need to be glued back together
