-   -   Can you replace Keller Door lock on a '73 Tradewind with a Bargman L-400? (http://www.airforums.com/forums/f164/can-you-replace-keller-door-lock-on-a-73-tradewind-with-a-bargman-l-400-a-83368.html)
montanablue 10-06-2011 09:14 AM
Does anybody have experience with replacing the Keeler door lock on a 73 or similar Airstream with a Bargman L-400 or other door lock? Maybe someone has some suggestions.
Rick
Inland RV Center, In 10-06-2011 10:34 AM
Rick
The L-400 is history.
There are Trimark locks kits available.
Also, Keeler Brass locks were not used until the 1978 models.
Andy 12.1K
montanablue 10-06-2011 01:21 PM
Thanks, but I do have a question. What was the stock door lock for the 73 Tradewind? I was told it was a Keeler. Are you saying that it is a Bargman L-400. I have access to a L-400. Or maybe I can get a rebuild kit for the Keeler. The chrome is coming off. I would like to bring it back to life or at least make the door look better with a new lock. Function of the old lock is not the best.
Rick
Inland RV Center, In 10-06-2011 01:39 PM
Rick
The entrance door lock for all Airstream trailers from 1970 to 1977, used a KT lock.
If the entrance door was changed out, it could have the Keeler Brass version.
For your info, the L-400 will not work, unless you considerably modify it.
