-   Generators & Solar Power (http://www.airforums.com/forums/f448/)
-   -   What model # is this? (http://www.airforums.com/forums/f448/what-model-is-this-79902.html)
MrJ 07-19-2011 12:29 PM
Bought a MH and need to pick it up. (76 model) I want to order generator parts before I get there so I can fix and use it.
Questions:
1. What model # is this
2. Assuming it's been sitting for a year what should I purchase for it
3. Doesn't start without being manually choked - what should I do or purchase.
4. To make this generator as solid as possible what should I replace, upgrade, etc
5. How does the gas line attach to the tank
Thanks for the help.
DKB_SATX 07-19-2011 12:57 PM
It looks like the model # is stamped on the black-and-metal tag that has "Onan" as the first line of text. I can't get enough resolution out of the photo to read the stamped number, but you can probably read it when you're looking at the tag in person. Maybe you can get the seller to read the # for you if no one can definitively ID the gen set and you won't be near the motorhome before you go to bring it home.
