-   -   Patio light-08 Classic (http://www.airforums.com/forums/f44/patio-light-08-classic-79303.html)
ronster737 07-05-2011 02:19 PM
All,
Was changing out a patio light due to corrosion on my 08 Classic. Light worked prior to change. Turned off switch, cut single wire and wired in new light. No light. All fuses ok, etc.....any ideas?
Cheers, Ron
dznf0g 07-05-2011 02:37 PM
Bad ground?
ronster737 07-05-2011 03:19 PM
Turns out light in hand doesn't work as well as light installed! Learning as I go along! Guess it grounds on trailer.
Since you are 'Rivet Master', any idea on size/type rivets for the bottom storage doors along the outside latches? Gonna replace those too.
Thanks for the reply!
Cheers, Ron
