-   -   Fuse Box for 2008 Safari SE 20? (http://www.airforums.com/forums/f447/fuse-box-for-2008-safari-se-20-a-79232.html)
Mrs. Bale 07-03-2011 08:36 PM
We just brought our beautiful new Airstream home yesterday, and this morning, for some reason, the ceiling lights in the bathroom and dinette (both on the same side of the trailer) won't work. They worked yesterday! I tried to find the fuse box and can't locate it. Does anyone have any suggestions? Thank you!
dkottum 07-03-2011 10:52 PM
The fuse box and converter are located under the front of the refrigerator. There is a small knob on the lid, turn it 1/4 turn and it will open. There should be a label on the inside lid, and there should be one labeled bath lights (maybe more on that circuit).
Also note that on the bath lights there is a wall switch and each fixture has its own switch. The wall switch must be on before the fixture switches will work.
doug k
dkottum 07-04-2011 09:01 AM
One reason for blown fuses may be very low battery voltage. Our original batteries were shot last year (wouldn't hold a charge). Your trailer is one year newer.
doug k
