-   -   Foggy front curved windows (http://www.airforums.com/forums/f164/foggy-front-curved-windows-78265.html)
adamgraves 06-06-2011 10:13 PM
Any ideas how to clear the moisture from in between the two curved window glass panes on front of a 74 ambassador without removing frame from the shell??
waltero 08-04-2011 05:15 PM
On my 73 I verrrry carefully drilled from the underside , up between the two pieces of glass, allowing the moisture to escape, waited a couple of days , filled the drill holes with putty....I was worried that I would break one of the pained, but it worked.....
Waltero
tommybb 09-24-2011 07:45 PM
Broken curved front window
I shattered the right front window on my 1971 Overlander. Does anyone know if these are still available and how hard it would be to replace?
Lumatic 09-24-2011 07:52 PM
1.You can carefully break out the inner pane
2.Yes new replacement widows are available, but expensive. Try Inland RV. Used are also available 1970 to 75 R the same. Not too hard to replace but takes some time.
