-   -   AC Shroud (http://www.airforums.com/forums/f427/ac-shroud-77061.html)
skerby 05-06-2011 11:28 PM
AC Shroud
I have a 1972 Overlander, 27 Ft. The AC Shroud needs to be replaced, is this a universal part or do I have to get it from Airstream. I Have looked online and most of them are for Colemans...Thank you for your help
barts 05-07-2011 12:23 AM
Well, what kind of AC do you have? Inland RV sells shrouds... you can also consider fabricating your own; some possible construction methods are riveted aluminum or epoxy&fiberglass covered foam/wood.
- Bart
Inland RV Center, In 05-07-2011 12:54 AM
The original shroud is available, but made with fiberglass instead of plastic.
blickcd 05-08-2011 08:06 AM
Skerby, I have the shroud for my old Armstrong air conditrioner. It is in fair condition and I'd consider giving it to you so long as you paid the shipping from SW Ohio. Might be too big to send UPS. Send me a PM if you are interested.
Christopher
overlander63 05-08-2011 09:18 AM
Christopher
Before the OP gets too excited, that shroud won't fit the '72 Armstrong. The '72 had two fan motors with their vent holes in the shroud in different locations, instead of a single motor doing double duty.
Barry Mabus 02-16-2015 01:05 PM
What is the supplier source for the fiberglass shroud you reference?
