-   -   problem with rear window awning (http://www.airforums.com/forums/f159/problem-with-rear-window-awning-75560.html)
t7389sg 03-29-2011 08:02 AM
The cast hook is broken on the rear awning on my 91 350LE.
http://img.villagephotos.com/p/2005-...d3e7d8bd_b.jpg
I found this hook for sale but it does not have holes for 3 rivits. Do you think this is the right size to use on my moho and where can you find these extra large rivits?
http://odmrv.com/catalog/images/Awning/320119.jpg
I may order this one anyway because I have not seen any others for sale online.
airstream4 03-29-2011 08:13 AM
Call Zip Dee they have the hook and rivets! 2 or 3 rivets?
Paul
tkasten 03-29-2011 08:21 AM
That looks just like the hook that Zip Dee uses.
Inland RV Center, In 03-29-2011 10:09 AM
That hook comes from Zip Dee.
You can call them at 800-338-BEST.
Ask for Linda.
t7389sg 03-29-2011 11:32 AM
Thank you Andy. I called and they don't make it with 3 holes any longer but the 2 hole design is the same size and should fit covering the middle hole or I could drill the middle myself. The hook is on the way. Problem solved. Thanks to everyone for your help.
Steve G
