-   -   Where to store your equalizer bars? (http://www.airforums.com/forums/f464/where-to-store-your-equalizer-bars-75544.html)
King O D Road 03-28-2011 06:03 PM
I got tired of cleaning the grease out of the back of the suburban from placing the equalizer bars inside and no room in the trunk of the coupe and did not like to clean the dirt out of the grease from laying them on the ground, so decided on a place to store them when not is use.
overlander63 03-28-2011 06:55 PM
I'm going to make you feel very stupid...
The holes in the knobbed (removable) end of the bars go into the posts sticking up from the snap up brackets for storage at the campsite. They don't take up as much room that way, they don't interfere witht he LP tanks, and nobody gets grease on them or their tow vehicle.
RichardT 03-28-2011 06:56 PM
That is cool
They actually have a hole in the end that fits onto the bracket to store them while parked.
King O D Road 03-28-2011 08:07 PM
Wow! Overlander63, I suppose that information was in the instruction manual I have never read. I appreciate your reply and would not have gone to all the trouble if I had Known that before making the stands. Tried it out and it works fine. Thanks again, Roger
TBRich 03-28-2011 08:18 PM
If you saw Roger's rig you would be amazed at what he's done with/for it...all the customization and just plain cool stuff. It is truly a gem... We were truly inspired. I'm sure the bar stands will get lots of attention from fellow admirers!
We have Equal-i-zer bars and there's no good place to put them. So Greg made bright yellow vinyl sleeves for them...so we can store them in the truck bed or underneath the trailer without getting them dirty or everything else greasy...and he put a flap the length of the sleeves with grommets along them so we can also use them doggie tie-downs...they are so heavy that we can clip the pups to them and they really keep them where we want them. We also use them to put at the edge of the rug if it's windy...keep it from rolling up in the breeze (that's why they are bright yellow)...
4RXLA 03-28-2011 11:30 PM
I have a draw-tite wd hitch and there is a tubular metal bracket on either side of the A frame that the spring bar slides into. The chain ends are near the coupler and I lock them together with the safety chains to prevent theft.
exthemius 03-29-2011 09:15 AM
Sorry for the crappy looking photo, but the only one I have of ours is the original pics we took when we bought the Airstream (now it's all painted and restored). At any rate I believe this would be what dougsale is referring to (as we do the exact same thing with ours -- lock them up front).
Attachment 125662
Bluto 03-29-2011 09:43 AM
I'm trying to picture this in my head but, no use. Now I feel really, really stupid.
Do you have a picture you can post of how you use the snap up bracket to aid in the storage of the bars?
Inland RV Center, In 03-29-2011 09:50 AM
There is a hole in the trunion end of the torsion bar. The trunion end is the part that goes into the ball mount.
That hole accepts the very top of the "snap up" bracket, which is the part the sticks up in the air, that you use with a small pipe to load the torsion bars.
Antique Pedaler 03-29-2011 09:55 AM
Grease? Who uses grease? Isn't the idea of the bars is to create friction?
Inland RV Center, In 03-29-2011 10:04 AM
The idea in the case of Reese torsion bars, is to create "torsion", not friction.
Hence the name, torsion.
Bluto 03-29-2011 10:16 AM
Thanks Andy, now I understand.
UAPachyderm 03-29-2011 10:29 AM
Wow, I never knew this. Can someone post a picture? ... I'm not near my AS and unable to envision this.
HCR 03-29-2011 10:30 AM
Exactly what parts are intended to be "greased" on the equalizer hitch?
