-   -   BoltLock: hitch reciever lock uses vehicle key (http://www.airforums.com/forums/f464/boltlock-hitch-reciever-lock-uses-vehicle-key-75151.html)
Wayward 03-17-2011 09:41 PM
Uses the ignition key. They also have padlocks, cable locks and spare tire locks. One key.
BOLT Locks by Strattec — One-Key Lock Technology - Learns YOUR key the first time you use them
http://www.boltlock.com/shop/images/110
Too bad Airstream hasn't figured the concept out.
Jammer 03-18-2011 01:29 PM
Indeed. I've noted elsewhere that it's possible to adapt the battery compartment locks to the water door and save one key but that still leaves far too many.
I have not had good results with other brands of locking receiver pins. The locks fail quickly due to road spray. I currently use a non-locking pin. If I were concerned about tampering or nuisance theft I'd use a grade 8 bolt with a locknut, a combination that is difficult and time consuming to remove without a ratchet.
