-   -   Replacement lock cylinders or keys? (http://www.airforums.com/forums/f164/replacement-lock-cylinders-or-keys-74731.html)
Atomichoe094 03-06-2011 11:06 AM
Hi all, new guy here with a 1986 34' excella trailer. The front door locks were drilled out so ill be needing to get some new ones of those and i never got any keys when i bought it. so all the small doors and such on the exterior are locked. Anyway i can still get new locks and keys for these? thanks!
Inland RV Center, In 03-06-2011 11:11 AM
Those parts are still available.
c_lewis77 03-06-2011 11:18 AM
I was also missing keys on all of the hatches/battery doors/water fill for my 83 ltd when I bought it. I had a locksmith come over and he made me keys for all of the locks on the trailer (less the front door) in about 20 minutes. It was easier than replacing the cam locks.
overlander63 03-06-2011 11:20 AM
Welcome to the forums. Most of the compartment locks are a "standard" key, a trip to your Airstream dealer should fix you up with them. If your main door lock wasn't damaged, you can probably get a new lock cylinder with keys. I'll have to look tomorrow to make sure.
Bill M. 03-06-2011 11:21 AM
I had the deadbolt drilled on a 87 Excella. Do not know how yours is mounted, but to get my handle off to take the lock out one would have to take of the interior door trim, the window trim, a interior panel, and most of another panel. I found a airstream dealer with the lock, which was listed at $120. I ended up just leaving the original deadbolt in place and having a new deadbolt mounted just below the handle and in line with the trim. Fifty bucks and a half hour.
Wabbiteer 03-06-2011 11:51 AM
One of the Airstream dealers in Arizona mailed me the water-fill compartment door key, a sneaky double-cut one I couldn't pick - shipping was at cost for key taped to a piece of cardboard in 1st class envelope. Very painless.
Atomichoe094 03-06-2011 08:53 PM
Thanks guys for the reply's back. Ill have to look into this more and check around. Supposedly theres a big airstream place in Columbus Ohio?? Ill have to give them a call and see whats going on. For the mean time, heres a couple pictures if it helps anyone out. thanks!
http://img834.imageshack.us/img834/3531/mvc001.jpg
http://img690.imageshack.us/img690/1607/mvc014.jpg
http://img717.imageshack.us/img717/3900/mvc013.jpg
Atomichoe094 04-06-2011 05:53 PM
Still no luck on this deadbolt at the top of the handle. Called around and everyones wanting 200 and some dollars. plus fifty for the little rod behind it..
nicholaskmt 07-02-2011 09:28 AM
I found a lock cylinder with keys for my front door at Crain RV Supercenter in Little Rock, AR. It is a Keeler clyinder and they have 98 left in stock at this point. I have a '78 Excella and had already found a stainless steel latch handle for this lock being made by John Burkey of Magadore, Ohio. Hope this helps someone.
