-   -   64 bath sink sprayer (http://www.airforums.com/forums/f446/64-bath-sink-sprayer-73018.html)
donh1 01-11-2011 10:54 AM
have leaky sprayer that needs to be removed since we don't use it. how do I get the sprayer hose out and stopped - do I need to remove sink? If so, how do you get the sink out?
overlander63 01-11-2011 01:21 PM
You should be able to get to it from inside the rear compartment. Some flexibility on your part may be required. You can probably put a plug or cap where the line for the sprayer comes out, and you shouldn't have to take the sink out. If the sink isn't one of those molded-to-the-counter ones, it may be easier to get to, though. Just a dozen or so 5/16" or 3/8" clamp bolts and disconnect the P trap.
NicheVintage 01-11-2011 02:05 PM
We were able to access our for replacement under the sink. My husband got down in the tub and could reach it from there. It is a bear to get to. You should be able to cap it off. I think most are run off the cold water supply line. Good luck.
donh1 01-11-2011 02:13 PM
Thanks but getting down in the tub and looking up under the sink; there is no access hole or anything. Did you have an opening under the sink?
NicheVintage 01-11-2011 02:18 PM
On ours there is an opening in the back.
VIKING 01-11-2011 05:11 PM
My faucet had the shower riser attached to the top of the faucet. It wouldn't be necessary to get under the sink on mine, though there is an access hole.
I found out that not all '64s had this hole. I can remove the faucet and disconnect all of the under-sink plumbing from inside there with a lot of contorting and straining. This is where I learned "blind-plumbing".
Best to you,
Rich the Viking
