-   Water Heaters, Filters & Pumps (http://www.airforums.com/forums/f445/)
-   -   Panel indicator light for water pump and Water heater (http://www.airforums.com/forums/f445/panel-indicator-light-for-water-pump-and-water-heater-72850.html)
DJW 01-05-2011 06:15 PM
Hello all, My new-to-me, and barely used '04 Safari LS has an indicator light on the panel above the stove for the water pump. The pump works fine, but the light never goes on. Is it suppose to?
Same issue in the bath room- indicator light for the water heater never goes on, but the WH works just dandy.
Suggestions?
Don
SteveH 01-05-2011 07:27 PM
Don't know about the water pump light....might be simply burt out, but the water heater light is sort of an alarm light. It only lights when there is a problem and the heater won't relight correctly.
To test that, turn off the gas and turn on the water heater. The red light should come on then.
bolerama 01-05-2011 07:28 PM
Don
The light is working correctly. It will flicker (once) when the hot water tank is trying to light. It will stay light if the tank doesn't light (usually when there is no propane in the line)
All the best
Paul
Jim Foster 01-05-2011 08:01 PM
Originally Posted by bolerama (Post 934247)
Don
All the best
Paul
That's the way the one works on our '83. When I turn the water heater switch on, the switch glows red until the water heater lights, then it goes out.
Check the bulb on the water pump light.
