-   -   Factory Headers? (http://www.airforums.com/forums/f159/factory-headers-6913.html)
swebster 09-25-2003 04:48 PM
Factory Headers?
Saw these listed on ebaymotors today as "factory headers". I have these on my 86. Were these a replacement for the cast iron manifolds? The ebay seller mentions solving the problem of cracking manifolds. I've been saving up for a Thorley/Flowmaster replacement some day...are there any advantages/disadvantages to keeping these on the MH? Everyone I talk to tells me about cracking manifolds so I'm not sure if I should feel better with these or not.
87MH 09-25-2003 04:58 PM
"Factory Headers"
Steve:
I have the same set up on my '87. I did not know if it was added or factory. I have not found in the documentation where any work was done to the exhaust, so I am leaning toward the "factory" installation.
The expansion joint in the middle sure can't hurt.
With 75,000 miles on it, I don't have any exhaust problems.
I do have a vaccuum powered throttle valve installed just downstream of the manifold on the drivers side manifold only.
Even though the valve is free, I often wonder if this valve is the source of my pitiful gas mileage.
I only get 4-5 mpg, on the initial retrieval trip I recorded 7-8 mpg.
Only thing done to the motor since then was new plugs and plug wires.
swebster 09-25-2003 05:06 PM
163,000 on mine but a "rumored rebuild" 8K ago. Must have been done at some point as I can't believe a stock 454 would still run so well after pulling a 345 this far!
I have that valve as well. I've been getting a good 7 - 8 mpg after several trips. Also replaced cap, rotor, wires, made carb adjustments and plugs (all at the dealer) before going on first trip. Still feel like the carb needs some love though.
I'm sure one of our gurus will help on this one. If I do replace these with headers I'm not sure what do I do with all of that "extra" junk on the current manifolds/headers. Looks like an air pump sends air through smaller SS manifolds into the exhaust headers at each port. I actually think I have a small leak in one on the drivers side which I first feared was a cracked manifold.
74Argosy24MH 09-25-2003 07:28 PM
Factory manifolds, GM's admission there was a cracking problem.
There is an exhaust passage through the intake manifold and both heads. The valve should close when the engine is cold, the exhaust heats the manifold up faster.
87MH 09-26-2003 12:57 PM
There is an exhaust passage through the intake manifold and both heads.....
John:
If I interpret your post correctly, there is an exhaust "cross flow" from the driver's side manifold, through the intake manifold, and exiting the curb side manifold when the exhaust back pressure valve is closed? (Engine is cold.)
Wow, that's a new one on me. Lots to learn.
Taking it one step further, with no vacuum to the back pressure valve controller, a spring holds the valve in one position, immediately upon starting, vacuum causes the valve to go full to the opposite position.
That being the case, as the engine warms up, the vacuum SHOULD BE dumped, letting the valve return, via holding spring power, to the original cold, non-running position?
I ask this, because there is no indication of valve position on the valve itself.
I started to disassemble the valve, but one of the three studs would not free, and I torqued it up a bit, so not wanting to cut, drill, and e-z- out a stud, I left it alone.
I have a "point and read" thermal indicator on order, but this information will be helpful in determining the proper operation of the exhaust back pressure valve.
thenewkid64 09-26-2003 01:02 PM
Dennis,
There is a GMC Coach site that does a ton of rebuilds on the 455 engines. They quite often fill this crossover port with molten metal when rebuilding the top of an engine. I am not sure why, but it has been an area of frequent trouble, from what I have read this is a weak point that tended to crack.
Link to the page where they show this.
Pouring molten Zinc into the crossover port
74Argosy24MH 09-26-2003 03:15 PM
Yes, it should close when cold and let the exhaust flow normally when warm. I doubt if all the exhaust flows through the manifold, it isn't a very large opening.
GM Coop is classy. All I ever did was jam aluminum foil into the intake and use the filler that came with the intake gasket.
swebster 09-26-2003 03:28 PM
So if I went the Thorley (or Banks if I win the lottery) you would simply remove this gear and plug up the openings? Any advantage to just keeping the stock manifolds and adding a flowmaster exhaust?
74Argosy24MH 09-26-2003 03:59 PM
If you don't have to worry about emissions testing tear it all off and go with the headers. Using a free flowing exhaust is better than stock, but the header swap is where you will really improve performance and mileage.
swebster 09-26-2003 04:45 PM
John thanks! Good to know. KY doesn't test over 15,000 lbs so mine is immune. :) Now I just need enough freelance work to get the header purchase past the budgeting queen! Maybe I take a queue from Brett and go with the...it's suddenly broken routine!
Seriously, I have kind of a PO special for an exhaust system. Some original and two mufflers that were literally crushed to fit (not pretty)...so going free flow has been in the plan. Add a new carb and a Tornado and maybe I'll see 10+ mpg some day!
74Argosy24MH 09-26-2003 05:05 PM
I have heard of shade tree mechanics, now we've got cave man mechanics. You won't have to imitate Brett, rust will take care of them pretty fast once the aluminizing layer gets busted and scraped up.
87MH 08-30-2004 12:20 PM
Header Question for Gear Heads
Hey, guys.....
Could anyone identify which manufacturer might have made these headers?
I picked them up at Colaw's in May of 2004, I know they came off of a 454 and seemed to be in pretty fair shape overall - just had a light coat of surface rust when I inspected them. The "shelf" on the curb side manifold is a heat shield, the chrome "handle" appears to be a mounting assist.
A company here in Houston "Metalized" the surface with the new "Kolene" process. Great people to do business with -- ask for "Eric".
http://www.houstonplating.com/
Here are the photos of the Headers after the "Kolene" plating (coating) process.
Thanks.
swebster 08-30-2004 12:27 PM
Hmmm. They definately do not look like my Hedmanns. Long primaries. What is that plate on the pass side for?
swebster 08-30-2004 12:29 PM
oh...just re-read your post...heat shield. I think the "handle" is actually for the hot air intake to your air cleaner horn.
