-   -   Wiperblades!? (http://www.airforums.com/forums/f156/wiperblades-6449.html)
Curtis-79MH 08-31-2003 11:24 PM
Wiperblades!?
I've tried all the parts stores here in Anchorage trying to find a set of wiperblades for my '79 28 foot motorhome. Does anyone know where to get them online or mail order? Part numbers and manufacturer info would help as well. Were getting ready for a big trip that could involve rain and may I daresay (shhhhh...snow).
I know if I put ON new wiper blades I'll guarantee we'lll have sun and warmth:D and if I don't......yikes!!
Thanks again, Curtis
PeterH-Airstreamer 09-01-2003 06:42 AM
This will work until you find the right replacements. All you need is a small bolt with a locknut !! and two washers. Even the windshield washer nozzle can be mounted on the small nut/bolt.
Note the 2 holes style wiper arms.
74Argosy24MH 09-01-2003 07:05 AM
If it will keep the snow away, try Cleveland Ignition. You have to order over the phone but they have an 800 number. My blades are 20" Anco.
Astrodokk 09-01-2003 08:35 AM
Wipers
I had the hardest time finding these for my "81 28' MH. Finally got them at Napa Auto parts. The problem was the width of the refill blade...they are wider than standard. The part # is 60-2009 for $6.29 each. I forget the length but I believe it's between 20-22 inches. I think we have the same windshields so they may be the same wipers for us. Good luck.
overlander63 09-01-2003 11:57 AM
Do you have such things as truck stops up there? Even someone that specializes in HD truck parts may be able to help you, if you don't have a Napa, or similar, parts store.
Snow? What snow?
(in Florida):D
jthew1 09-09-2003 07:46 AM
Wiper Blades
My 86 -345 has a 20" blade availble from NAPA, part# 60-2065 for $9.45 each. Comes complete with screw, locknut and adapter, if required.
Hope this helps?
