-   -   Kohler generator fuel filter (http://www.airforums.com/forums/f159/kohler-generator-fuel-filter-6257.html)
ViewRVs 08-22-2003 05:01 AM
According to my manual, my Kohler gen set has only a metal screen fuel filter. I am getting some rough running and shutting down lately. Brett suspects a clogged fuel filter. Since I have had fuel filter issues with the main engine, that's probably a good hunch!
Once I clean out the screen filter, I would like to install an in-line filter. Should I do this in the gen set compartment or is that not a good idea? The line comes in from near the top and I think I can keep the line away from the hot running engine.
PeterH-Airstreamer 08-22-2003 05:25 AM
Get one of those glass inline filters, they come for 3/8" and 1/4" lines. Adding the inline filter will give you even more room for fuel line routing. I kinda doubt that your troubles are in the fuel filter, since the pick up for the genset fuel is way above the bottom of the tank.
Disclaimer: This information is for entertainment purposes only. Always check with your OEM when making changes to the fuel delivery system. ;)
ALANSD 08-22-2003 02:49 PM
I had posted before on this.. my Onan runs well, but stalled when rounding curves on a recent trip. I am headed to NAPA this weekend for a new fuel filter, hope that is the trick. The plugs and all look good, and I have cleaned the carb on it.
wb13798 08-23-2003 06:17 AM
my gen set has been runing rough at time for the past year. my onan repairman says carberator needs cleaned to include filters. i have a filter on the carb and one laying in the compartment . how does trash get thru two filters.
i bought a carb off ebay that was a new take off. swaped the carbs and filters out last eve and the generator is runnung like a new one.lol
al
