-   2001 Safari (http://www.airforums.com/forums/f197/)
-   -   Removing rear twin beds (http://www.airforums.com/forums/f197/removing-rear-twin-beds-6193.html)
Bud Brown 08-18-2003 06:36 PM
Has anyone removed the rear twin bed frames and night stand from their 2001 Safari? Any issues or is it just removing screws?
Princer 08-18-2003 07:05 PM
rear twin bed removal
I have gone the other way. I removed the bedside nightstand and queen bed from a 2001 Sarafi--and it was only a "remove screw" activity. I used much of the removed materials to make a new "between the beds" night stand and bed boxes. Under one bed box is the outside storage compartment. Under the other is storage , made out of the under bed storage cabinet from the queen configuration. I sort of know how to do this. What I did looks professional--especially since I experimented with many stains on the oak plywood I used to do the modifications. It is nearly impossible to tell what I stained and finished, compared to the rest of the Safari interior. You can call me to discuss the project, which included moving the circuit breaker box.
John Prince at johnprince@aol.com or 936-449-4345
dcasr 12-24-2010 07:29 AM
I have removed rear twins and night stand in my 1990 Excella and I have an absolute I have learned the hard way. Photograph how things look before you start, then at every significant level of disassembly. Have a box of plastic baggies and put the screws or nails in a separate labeled baggie for each area and part of the disassembly. You may think you will remember, but most likely you will only come close. Good Luck.
1966mustang 05-25-2013 10:47 AM
Putting back twin beds from previous bad conversion to double. The nightstand was cut to fit conversion. Does anyone have the side panel dimension & counter top dimensions for a 1986 Soveriegn 29 ft.
