-   -   Checking water in the battery... (http://www.airforums.com/forums/f37/checking-water-in-the-battery-6129.html)
drboyd 08-15-2003 09:51 PM
...is a major pain in the *** in my Tradewind! It's got a front battery door that folds out and down, but the way my propane tanks sit, I've gotta unbolt them and move the one on that side forward a couple inches to get the door all the way open.
Then, of course, the battery is packed into the box and weighs a ton. Then, when you put it back, the top of the box is warped down, so you've gotta pry it up to get the battery back in.
Seems like a lot of trouble for a battery water check... at least compared to a car.
What's anybody doing about this? Y'all got some magic battery that never needs water I can buy when this one dies?
thenewkid64 08-15-2003 10:37 PM
If you want Maintence free then you need to be prepared to spend some $$$. AGM or Gel batteries require no maintence and can be mounted in any position. They are availabel at marine stores or you can ored a optima blue top for your local auto parts store.
Sounds good, huh? The only problem is that proper maintence of a Gel or AGM can require diffrent charging voltages than the univolt may put out. If you have a more intelligent charger you can tell it what kind of battery you have and it will do it right.
I do not remeber the voltages for sure but I think Gel 's were 14.5 charge and 13.5 float????
