-   2005 Safari (http://www.airforums.com/forums/f292/)
-   -   creak/squeak in floor (http://www.airforums.com/forums/f292/creak-squeak-in-floor-59082.html)
jmtandem 12-03-2009 12:36 PM
I am looking to purchase a 2005 Safari 28 with the slide out. It is in good shape overall but I recall from research on these fourms that some came with a quirk/creak in the floor. This is near the rear of the hallway under and just forward of the privacy curtain. It is covered with wood or vinyl and not carpet so I am reluctant to get under the covering on something I don't own. Is this creak normal for Airstream floors or should I be concerned with dry rot underneath. Any ideas or suggestions will be appreciated. Thanks.
TinShack 12-03-2009 12:44 PM
I have that same squeak in my 28 SO too. It's been there since day 1 when I purchased it new. 3 and a half years later it hasn't gotten any better or worse so I've just lived with it.
2airishuman 12-03-2009 03:09 PM
common issue, not confined to slide models...
scan any of the Q threads and this issue is a recurrent annoyance mentioned across the models (except 16s)
http://www.airforums.com/forums/f44/...oor-48941.html
but this issue is buried in LOTS of threads and subfloors.
cheers
2air'
jmtandem 12-03-2009 06:38 PM
thanks, I guess it is just one of the Airstream quirks. I am still learning coming from three cabover campers and one 30 foot travel trailer.
CanoeStream 12-03-2009 07:33 PM
I opted for no carpet and all-linoleum floor when I ordered my 2006 Safari. It takes some observation but I know where the seam between plywood sheets is located. Yes, there is a bit of creak at odd times. I agree that it stays stable and I'm not inconvenienced. A creaky day airstreaming beats a medium day AirForums'ing... :angel:
FreshAir 12-03-2009 10:38 PM
Creaks and squeaky doors......I leave 'em be. Tells me when someones a sneaking up on me. :D
Neil.
Fyrzowt 12-03-2009 11:13 PM
Hi jmtandom,
My 2000 Safari has the squeek also, just forward of the bathroom/privacy curtain.
Welcome to the forums!
Dave
JRM 06-11-2018 06:14 AM
I had the same problem there was a couple of screws on the inside behind the furnace cover
that needed to be tightened down on the floor took care of the problem
