-   General Motorhome Topics (http://www.airforums.com/forums/f160/)
-   -   Gas pedal and cruise control question (http://www.airforums.com/forums/f160/gas-pedal-and-cruise-control-question-56575.html)
willerjim 09-20-2009 02:37 PM
82 280 motorhome. Require a lot of foot pressure.
I have an aftermaket- new- cruise. Anyone ever installed one?
Questin is- will these aftermarket systems overcome 5-10 lbs of pedal pressure?
Anyone ever installed a different gas pedal?
Jim in Denver
HowieE 09-20-2009 03:02 PM
I would try and figure out what is the cause of the heavy foot pressure before you attempt to install the control. Most controls pull directly on the throttle arm at the carb or fuel injection body and may have trouble. Is the problem in the peddle hinging or is the cable just rusted up?
Try disconnecting the peddle and see if the problem is in it as apposed to the cable.
