-   1965-1969 Sovereign (http://www.airforums.com/forums/f303/)
-   -   Radio Speakers but no Radio 1969 ???? (http://www.airforums.com/forums/f303/radio-speakers-but-no-radio-1969-a-50108.html)
tdoescher 04-08-2009 09:46 PM
Ok I just bought this 69 Sovereign Airstream and there is speakers in the front cabin and rear sleeping room but there is no radio to be found. I did not see anything in the front console or any place there was a radio spot that appeared to be removed. Anybody have a 69 with a original radio installed? What am i not seeing?
Thanks Todd :blink:
Inland RV Center, In 04-08-2009 11:33 PM
Thanks Todd :blink:
So to speak, the speakers were standard.
The Radio was an option.
If I remember correctly, the Radio was installed, when it was installed, in the front rooflocker, over the front window.
markdoane 04-09-2009 08:22 AM
If I remember correctly, the Radio was installed, when it was installed, in the front rooflocker. . . .
Rooflocker?
Great, now I'll be dragging around an image of a white fluffy kangaroo all day.
:lol:
arodriguez60 04-09-2009 08:30 AM
On my 69 tradewind it doesn't have the radio but looks like it was in the rooflocker like Andy said
Lumatic 04-09-2009 08:41 AM
On my 71 ditto on the roo flocker. If you are lucky the coach was prewired for the radio and if you pull the console you may find the wires. Does your 69 have a "Master Control Center" up front above the flocker? That would be easy to remove and you may be able to find the wires.
trucker101 04-09-2009 01:33 PM
If it helps,mine is in the cupboard above the sofa. Click on the pic to make it larger.
http://img7.imageshack.us/img7/1333/dsc07612.th.jpg
bikrmikey 04-09-2009 02:49 PM
My 71 has the no radio plus no speakers problem. However I know where the wrires are. My speaker wires come out in the front overhead area, if I pull my control panel I can see all the wiring is in place.
I opted to go with an MP3 player and computer speakers that power off 12 volt.
goransons 04-09-2009 06:58 PM
if you remove the thumb screw that holds the clock and thermometer in place, and hinge that down, you'll see the access to the control panel inner workings. Inside you should see the wire pulls from behind the end cap and 4 sets of gray speaker wire, that should be your two front and two mid-trailer speaker wires. There is also 12 volt inside there you can tie your stereo into. The stereo location was on the street side upper cabinet "rooflocker"
Engtech05 04-23-2009 06:49 AM
My 69 has the speakers and PO installed a radio with mp3 player, all of the wiring was in the rooflocker
Cracker 04-23-2009 05:49 PM
My radio is in the rooflocker too! Great addition to the Airstream dictionary Andy!
Lothlorian 04-23-2009 06:09 PM
Just go buy a car radio that has an auxilary jack for mp3 players etc, and put it in. Get a flat panel screen TV and hook it up to the radio and you will have the best sounding system. My TV and Radio rock. I bought my radio on sale for $38.00 and the 19" flat panel screen TV was a gift from my kids. I paid $18.00 for four new speakers at Walmart and now I am all hooked up. We like the sound system so much we will go watch movies in the airstream.
Aage 04-24-2009 09:55 PM
8-track radio in my 74 Sov
Imagine you are sitting on the couch, facing the rear of the trailer. Slide as far as you can go to your right, and reach over to the wall and pull open the wooden panel to flip out the Motorola AM-FM Stereo 8-track radio.
http://www.airforums.com/attachments...1c048640d5.jpg
Slide in an 8-track of the songs in this video and have a blast! Top 20 Hits of 1974
Oh, and if you blow a fuse, here's how to get at it:
http://www.airforums.com/attachments...98e0d0ea96.jpg
The only equipment in the overhead bin is the thermometer and clock.
bellastream 04-21-2015 09:13 AM
Where are the mid trailer speaker locations? Can anyone tell me
Aage 04-21-2015 01:17 PM
On my '74 31-footer, there are a pair in the front, fairly high up on the wall, and behind the curtains, plus a pair in the walls of the mid sleeping area, again up and behind the curtains.
I would consider those to be the mid ones, but there are no rear ones in that layout.
If you have a rear bedroom, I would look in there, same height.
