-   Off Topic Forum (http://www.airforums.com/forums/f161/)
-   -   I didn't think (http://www.airforums.com/forums/f161/i-didnt-think-49836.html)
CanoeStream 03-31-2009 11:03 PM
I didn't think
My '06 was built in the unlubed bearing period when Airstream installed higher capacity Dexter axles for a few months. I think my GAWR is about 7200#. Tongue weight doesn't count against that, so I thought I had leeway to break the mold. Am I mistaken?
This picture shows my Safari tilted to the left. Towing is getting to be a real "Hey, watch this!" experience.
Attachment 77731
I got a great deal on a 1925 wood cookstove. The aluminum color and nickeled steel fittings seemed an Airstream natural, so I thought, "What could go wrong?"
Attachment 77732
I installed it in place of my roadside couch. It's over the axles so no rear end separation could happen. Wait. This gets good. I've re-routed the flue to the stack in the adjacent Dometic, so I have the first tri-fuel fridge in which wood is used. That's not really working yet but there's a more immediate issue.
Our Safari tilts to the roadside too much. Above 110 pounds pressure the tires look like something from Roger Rabbit. Anybody ever use airbags on just one side? The stove already adds almost 500#, so I'm not wanting to carry all my firewood on the curbside. Here's my best idea and the real question -- on the WD setup, how about 1000# springbars on the left and 500# springbars on the right? Has this been done before?
I won't even start in on what's happening with the outriggers...
Janet H 03-31-2009 11:11 PM
Nice stove!
Have you checked your running gear? So long as it's properly aligned and the tires are perfectly inflated, you should be fine.... :whistling
:lol:
markdoane 03-31-2009 11:48 PM
Bob,
I think if you took the bread keepers off the top you could move the thing closer to the wall.
Then it would be a simple matter to add a tag axle, just on that side, to take some of the weight. Or you could add a set of leaf springs on top of the torsion axle and increase it's capacity that way.
And I wouldn't put a 1000# bar on one side and a 500# on the other. It's much easier to just saw halfway through one of the bars to reduce it's rating.
. . . the moderators are sure up late tonight. Party is called off until they turn in.
overlander63 04-01-2009 12:19 AM
...And you did all this just today, Right?...
I'm going to go to the basement and let my Janitor in a Drum out...:rolleyes:
silverhawk 04-01-2009 05:07 AM
Goood Idea.:blink:
ts8501 04-01-2009 05:41 AM
Drop your tire pressure 30# on the passenger side of your TV. It will straighten the entire rig out (Airstream tiled left, TV tilted right).
310astream 04-01-2009 06:39 AM
Stack your fire wood on the opposite side. When it starts tilting back to the other side it's time to come home.
BigAl 04-01-2009 07:11 AM
April fool!!!
Nice one Bob.
Just put all the firewood on the other side.
Al
Lumatic 04-01-2009 07:28 AM
This is an April Fool's thing, right? Sometimes it's hard to tell.
I know there is a fireplace out there on the market that has been put in a few ASs. Originally designed for yachts.
ts8501 04-01-2009 07:35 AM
This is spot on serious. Let's not assume everything on 4/1 is a joke.
maccamper 04-01-2009 07:45 AM
Do you store your cast iron skillets in the oven? That could be part of the tilting problem? We keep the cast iron we travel with in the credenza on the opposite wall from our oven.
nancy mac
Boondocker 04-01-2009 08:40 AM
I counter balanced mine with the cast iron, claw foot tub on the opposite side.
funkill 04-01-2009 09:11 AM
Did you check to see if the witch is still in the oven? Maybe you could stack her on top of the firewood - or have her mix a spell to lighten the curb side load?
Sixty3TW4US 04-01-2009 09:34 AM
Maybe you can find another deal on a 1925 wood cookstove, put in on the other side and you will have a double cook top to feed us all. Proplem solved!! http://sv2s.com/community/images/smiles/Woo_Hoo.gif
