-   -   Power steering powered wiper motor? (http://www.airforums.com/forums/f159/power-steering-powered-wiper-motor-46818.html)
bkahler 12-07-2008 03:12 PM
While poking around an old mid 70s Revcon Motorhome I noticed that the wiper motor was not the typical one I've seen on other Motorhomes including our Classic Motorhomes.
Attachment 72322
I had never heard of this arrangement before. Is it a dependable and reliable system? My guess is its probably a bit more expensive to install and I wonder how it would operate while turning and braking at the same time?
Just curious.
J&C 12-07-2008 03:36 PM
Brad, How bizzzare! Charles said it should break the arms on an Icy windshield!
John B
bkahler 12-07-2008 03:40 PM
John B
I hadn't thought about the wiping power that would be involved using the power steering hydraulics. Maybe I aught to go back and pull that wiper motor!
ROBERTSUNRUS 12-08-2008 12:55 AM
Hydraulic wipers
:) Hi, back in the early seventys Lincoln Mark III's had hydraulic wipers. They worked very well and had about 15 speeds. The only draw back that I found back then was the fact that on the inlet side of the wiper motor was a filter screen; Most people didn't know about the filter and when it got clogged up [very rare] the wipers and power steering would be weak.
overlander63 12-08-2008 01:05 AM
Brad, did you follow the lines to the pump? I've seen wiper motors, especially on medium duty trucks, with vacuum-powered wipers.
bkahler 12-08-2008 11:58 AM
Terry,
I followed the lines down to the lower left front area of the engine. The lines appeared to be high pressure lines that connected to the wiper motor. When I first saw the arrangement I thought it was a vacuum arrangement. But after looking closer at the high pressure lines and where they were routed I decided it was operated from the power steering pump.
After having vacuum wipers on my first car (1955 Olds Delta 88 Deluxe) I decided I never wanted to use vacuum wipers again, especially in the winter in Nebraska! :lol:
bkahler 12-08-2008 12:00 PM
Originally Posted by ROBERTSUNRUS (Post 645849)
:) They worked very well and had about 15 speeds.
How was the speed adjusted from inside the car?!
Jim Foster 12-08-2008 12:26 PM
There will be one high pressure line, and one return line, just like the power steering unit.
My 1972 Chevy "Snap-On" truck had power brakes that were powered in the same way.
overlander63 12-08-2008 01:02 PM
Jim, do you know if that was a Hydroboost or Hydravac system? Not that it matters in this discussion, just curious.
Jim Foster 12-08-2008 01:21 PM
Yes, I think it was a Hydroboost, but I can't tell you for sure. Too many miles under the wheels since then.
Jim Foster 12-08-2008 01:31 PM
Just did a little search. Yes, it was a Hydro-boost. Worked just fine. They are used extensively on vehicles such as diesels which have no vacuum. My truck was gas, but I think it was used there as it could be placed sideways. The hood on that truck was very short.
wkerfoot 12-08-2008 01:54 PM
My 1977 Lincoln Continental has the same system for the power brakes.
Bill
overlander63 12-08-2008 02:37 PM
Bill
IIRC, your Continental also had something called "Anti-Skid" as an option. It was the first ABS system I am aware of, available from 1975-77 on higher-end models such as Grand Marquis, LTD Brougham, Town Car, and Continental.
Boy, we've dragged this thread way off topic, from power windshield wipers to ABS systems...:blush:
wkerfoot 12-08-2008 02:44 PM
Terry,
You are somewhat correct, in that I believe that the "Anti-Skid" option was available only with rear disc brakes. Perhaps standard on the Marks, since I think that they had rear disc brakes. My Lincoln has drums on the rear.
Bill
ROBERTSUNRUS 12-08-2008 10:46 PM
More information?
:) Hi, on the dash board was an ordinary wiper knob that turned on the wipers; It had several detents in the switch and each detent was a diffferent speed.
:) Hi, Hydro boost and hydaulic wipers worked from the power steering pump pressure. On 462 Lincolns the pump was mounted to the timing cover and turned directly from the crank shaft
:) Hi, my Mac Tools truck in 1986 built on a GM P-30 chassis with a Grumman Olsen body had hydro boost power brakes, and it was also a gas engine.
:) Hi, the early Ford/Lincoln ABS system was called "Sure Track"; It had a control module under the dash and a second vacuum booster and master cylinder mounted, on the frame, under the A/C evaporator case.
ROBERTSUNRUS 12-08-2008 11:01 PM
:) Hi, looking at the picture, the main body of this wiper motor looks very much like a vacuum motor, but vacuum wipers only had one small vacuum hose connected to it instead of the two larger hydraulic hoses. Also the cable connection from the in-dash switch is the same set up for both type motors.
Harry W 12-08-2008 11:10 PM
The 1966 T-bird had wipers operated with fluid from the power steering pump. I would guess that the '64 and '65 did also. The control was a lever that could be position anywhere from off to full on.
Rugger 12-24-2008 04:29 PM
My 1965 Lincoln Continental had the same set up as your T-Bird. It was a fully variable speed control and very reliable..no leaks or mechanical problems during the time I had the car.
