-   -   Know what this is? (http://www.airforums.com/forums/f164/know-what-this-is-45117.html)
1956Safari 09-13-2008 04:41 PM
Know what this is?
Can anyone point me in a direction here? I have one of these just under my regular door handle (56 Safari) and also one of these on the inside of the door in the same position. It looks like a basic handle but I cannot find pics of any anywhere. Any suggestion on what to do with it?
Attachment 67315
DEITZ645 09-13-2008 04:59 PM
1956Safari,
I think it is something to hold the door open. There will be a "male" piece on the door that will fit in the fixture in your picture keeping the door in the open position. Something like this...
http://shop.easternmarine.com/index....categoryID=462
1956Safari 09-13-2008 05:38 PM
You may be onto something. I see VTS carries this
1956Safari 09-13-2008 05:47 PM
Door handle?
Still does not make sense since this one on the inside of the door would not conect anywhere. I still thinkk it may be a knob. In this photo you can see the inside one.
Attachment 67317
RBolton 09-13-2008 06:10 PM
Is the outside piece directly opposite the inside piece? Does the hole go through the door and align with the other piece? Are the two pieces identical?
1956Safari 09-13-2008 09:49 PM
Yes the hole goes through to the other side. I guess it was another door knob?
centennialman 09-14-2008 08:07 AM
It could be the remnants of a deadbolt lock. Look on the door frame and see if there is a cut out, where the bolt would have slid from the door into the frame. Good luck with the mystery!:wally:
DEITZ645 09-14-2008 08:27 AM
1956 Safari,
I would have to concur with centennial man. I did not realize that it went from the outside of the door all the way through to the inside. Sorry to run you on a wild goose chase.
RBolton 09-14-2008 08:36 AM
Like this. I found this picture on Google
http://www.itisgood.org/64Globetrott...DoorScreen.JPG
1956Safari 09-14-2008 09:30 AM
Yes that's it. I will gladly add another lock on this suicide door! Now I need to see if I can find one to fill the ugly hole. Thanks guys!
