-   Audio, Video & TV (http://www.airforums.com/forums/f450/)
-   -   Part # for LCD mounting plate and strap (http://www.airforums.com/forums/f450/part-for-lcd-mounting-plate-and-strap-45078.html)
ericwarren 09-11-2008 09:27 PM
I just ordered the peerless articulating mount that A/S is using in the new units for the smaller (19") tvs.
now i need the plate and strap.
anyone have the right part #s?
also, i have an 06 19' int'l.
anyone know if the black wood is available to mount this to the spice rack?
thanks!!!
donshade 04-09-2009 08:05 PM
who did you order the mount from? I'm looking for one for my 19' Bambi
ericwarren 04-09-2009 11:10 PM
Amazon.com: Extended Reach Articulating LCD Wall Arm for 10IN-22IN LCD Scrns-sl: Electronics
Safari Tim 04-10-2009 10:55 PM
Eric,
I purchased the AS mounting plate a long time ago. I don't remember the part number. I just called a local dealer and asked for the plate. It did not include the strap or strap hardware.
I ended up putting two drawer handles on each side of the plate and got a long Velcro strap to keep the TV against the wall. Works fine for me.
Here is a blog entry I made when working on mine.
1960 Airstream Ambassador Project! Blog Archive Front flat screen mounted ….sort of
OB Bambi 04-16-2009 10:15 PM
I bought the exact same Peerless mount for my 19" television for my 19' Bambi---from Costco. I don't know if they still have it, that was a couple of years ago. Instead of mounting it on the spice rack, I mounted it to the bulkhead "wall" just to the right of the spice rack for a few reasons. 1) It doesn't take up as much room (You can use all of the rack).
2) I think it looks better
3) Uses the entire swivel of the Peerless mount
4) It seems stronger when at full extension.
I used a couple of strips of aluminum 1"X 1/8" cut about 5" long and drilled to back the two screws that came through the bulkhead next to the cabinet above the bed.
Just like the spice rack mount area, you can watch from the diner or in bed.
Randy Bowman
