-   -   Thetford Style II vs. Sealand Traveller Lite (http://www.airforums.com/forums/f446/thetford-style-ii-vs-sealand-traveller-lite-44456.html)
ronstory 08-17-2008 10:58 AM
Well, I started the day off measuring toilets, both in the house and the Safari. Hmm... it looks to be an interesting day. :bb:
The 75 Safari 23' needs a new toilet. The current model is a stylish gold Thetford Aqua Magic GL and I want to upgreat it new toilet with a residential size seat. The current toilet seat high from the floor is about 18.5", with 8" being the base that covers the black tank and 10.5" height in the toilet themselves. So I'll need the low profile version... and for referance the seat heigth of a standard house toilet about 16.5"... based on my sample size of 3 toilets from 3 different manufactures. :D
I've done a bunch of searches and while most folks seem to have used the Traveller lite for upgrades, I can't seem to find a comparison with newer small Aqua Magic Style II. Most of comments seem a 18-24 months ago were about the larger depth AM Style Plus in interferance with secret compartment.
The contender for the new throne seem to be the Thetford Aqua Magic Style II and Sealand Traveler Lite.
Now the specs:
AM Style II LP
Flange bolt # 2
Width-seat 15.06"
Height-seat 14.0"
Lenght 20.0"
Flange-center to back 9.5"
Weight 26lbs
Material: china-bowl/plastic
Pedal side: right
Traveler Lite LP 211
Flange bolt # 4
Width-seat 14.875"
Height-seat 12.125"
Lenght 19.0"
Flange-center to back 10.375"
Weight 33lbs
Material: china
Pedal side: left
My observations:
Style II (pluses / minuses)
+ Shorter flange center to back of unit length - won't be crammed to the secret compartment
+ A bit lighter in weight
+ Easy access to the pedal (next to sink cabinet)
+/- No flange conversion, I think. There seems to be a 11o'clock - 5 o'clock flange pattern (vs. 9 -3 o'clock) on older models but have not pulled it check
- Height, with plastic cover the seat would be 22" above floor - 5.5" higher than my house toilets
- Not all china
Travaler Lite (pluses / minuses)
+ lower seat height - 20ish", but still 3.5" higher than house toilets
+ All china construction
- Flange conversion needed - if using the "universal flange" conversion, not sure how much height it adds
- Pedal is now on the far side, right next to closet door
- slightly heavier
  1. So... Has anyone have any opinion on Aqua Magic Style II?
  2. Any thought on how much work is needed ot the flange conversion is on Sealand 4 bolt flange?
  3. How much the universal flange kit adds to the height?
All comments appreciated. :)
azflycaster 08-17-2008 11:24 AM
I saw one replacement toilet in a 76 TW that blocked access to the bathroom closet. Something to think about...
uwe 08-17-2008 11:25 AM
Originally Posted by ronstory (Post 604578)
[*]Any thought on how much work is needed ot the flange conversion is on Sealand 4 bolt flange?[*]How much the universal flange kit adds to the height?[/LIST]All comments appreciated. :)[/SIZE]
Remove toilet, unscrew old toilet flange from top of tank, replace with new 4-bolt toilet flange, if even needed.
No height difference.
If the old toilet flange has 4 holes, you won't need to do a thing.
Some of the original toilets had a plug in teh top casing that you can remove to access the rear bolt..with a socket and extensions.
A possible problem is that the old flange might be very stubborn towards removal. And, you might crack the black tank if you aren't careful.
I have successfully used Sealand porcelain toilets on projects. I do not feel the need to explore other brands at this time, the Sealands work so well, and alre easy to clean. Very little plastic on them. None where it counts.
Good luck with your replacement.
azflycaster 08-17-2008 11:44 AM
Speaking of toilets.:blush:
I am missing one of the rubber pads on the bottom of the seat. If anyone :rolleyes: is going to toss a Thetford Aqua Magic, I could use one of those pads. The parts pages at Thetford do not show the pads and I do not need a new seat.
Janet H 08-17-2008 12:42 PM
We also used the Sealand and are still happy with it. The old toilet had 2 bolts and the new one is set for 2 or 4. We rotated the old flange to meet the new bolt pattern and used a 2 bolt set up. We didn't use the universal adapter.
The seat that came with the traveler lite (a few years ago) was cheap flimsy plastic. But a standard household toilet seat fit and was an easy replacement.
Road Ruler 08-17-2008 12:48 PM
We installed the Sealand lite in our 1973 23' Safari.
4 issues
1. It is higher than normal
2. Flange, but adapters make it work (it adds 5/8 in to the height)
3. It is too long at the back and I had to get creative and indent a portion of the back wall to allow it to fit.
4 The flush pedal on the front left sits to far to the left. I had to shorten its mounting bracket so the plastic pedal could be installed and removed if needed without hitting the wall. I have pics somewhere if you want to see the mods.
The sealand works great once installed.
ronstory 08-17-2008 12:53 PM
Richard... when I toss the toilet, the rubber feet are yours... as well as the rest of the toilet. :)
Ron
ronstory 08-17-2008 12:55 PM
Going out to do more measurements....
ronstory 08-17-2008 01:21 PM
OK... here's the scoop
Center of flange to left wall 10.5"
Center of flange to back wall 10.5"
Center of flange to right bath cabinet 11.5"
Front of current toilet to back wall 19.375"
Backrest / secret compat door sticks out 1" from rear wall
Backrest / secret compat door bottom to floor 13.25"
Closet door clearance @ 6" open - dooredge to rear wall is 21" (Thank's Richard for reminding me of that dimension)
... now to look at the diagrams again.
ronstory 08-17-2008 01:28 PM
All--
Here is the illustration borrowed from the VTS website for the Traveler Lite. Based on the height of 14" at 10.375 rearwards of the flange... the compartment door would ahve to be modifed and would only leave about 0.25" of clearance ot the rear wall.
http://www.vintagetrailersupply.com/...VTS-411-2T.jpg http://www.vintagetrailersupply.com/...VTS-411-3T.jpg http://www.vintagetrailersupply.com/...VTS-411-4T.jpg http://www.vintagetrailersupply.com/.../VTS-411-4.jpg
Now to find some detailed Style II dimensions... ;)
Janet H 08-17-2008 01:44 PM
PPL has a lot of info on their website - maybe you can find what you need here. They have a large collection of schematics. RV Toilets, Holding Tanks & Sanitation
ronstory 08-17-2008 05:15 PM
OK... got distracted by some silicone I missed before...
Back to the toilet... the current Aqua Magic GL is about 19.5 longs and tucks right up to the rear wall. If I use the new Style II, it will give me about 0.75" more room in the back and move the front forward about 1.25" forward, which should allow the closet door to still open. Now the problem is that it's 3.5" taller... which will interfer with opening the secret compartment door... and I'll probably need a build a platform to put one's feet on. (sigh)
Life is never simple.
overlander63 08-17-2008 06:55 PM
We put a Style II in our Sovereign (high profile), a caveat is that the plumbing standards have changed in the last 30+ years. You will need to change the fitting from the pipe to the toilet (for any new toilet).
azflycaster 08-17-2008 07:16 PM
My closet door clears the toilet by almost 3 inches, you should be fine. I did not find out about the secret door until about a year after I bought the trailer. Went down a bumpy dirt road and it opened up. The PO left me a nice plastic mug from ghost ranch. Thanks Ken...
